indydieselnut
- Jan 20, 2009
Nothing earth-shattering here, just made some power cords using this basic recipe:
DIY Mains Power Cable (Belden 83803)
I left the techflex off and used Wattgate economy plugs instead of the Marinco. I thought the Belden 83803 looked great naked...no need to cover it up.
One question for those that have done this before - getting enough of the braided sheild twisted together to make it into the ground plug seemed really tricky. Do you just make one long cut down the braid and then twist the rest together? Seems like you create a lot of tiny, loose wires that way but I couldnt' think of any other way.
Looking forward to more complex DIY projects in the future!!
