deadlierchair
- May 4, 2003
Hey everyone,
This is my first build ever, so I'm really hoping I have just made some stupid mistake that's obvious
I've built the CMoy amp exactly to specification as listed on the Tangent web site. I am currently using two 9 V batteries for power wired in series (I think...it gives me a little less than 18 V when I test it on my meter). I am using the OPA2132PA op-amp. I have tested my 3.5 mm connectors many times and those are finally wired up correctly. Also, when I connect my power supply as shown below I get readings of 3 V on the negative side and 15 V on the positive side, is this normal? I get a clean 9/9 coming straight out of the power supply but when the circuit is active I get 15/3
Also...my problem is that I don't get a clear signal out of it. When I turn my CD player up all the way I can hear a little bit when there are highs in the music (ie a drum hit, loud guitar). I can definitely hear some electronic sound through the headphones so I think the amp is partially working. I was using iPod earbuds to test and my Sony D-EJ611 CD player as the output. I can hear when I go straight between the two but the amp is no luck so far.
Hopefully these pictures will help...
