Kal525
- Dec 1, 2002
alright, i've spent about a week and a half trying to come up with a reasonable parts list for this amplifier. PLEASE critique the hell out of this thing. I wanna know what's wrong with it before i actually order the parts.
It will be used for a home setup, wall powered, with sennheiser-hd600 headphones and a sound card as the source.
- AD8620 op-amp. I think i need 2 of these, tangent, on your site, it says you sell this mounted on an adaptor and tested. Is it just one of them mounted, or do i need to purchase 2.
- C1 1.0 uF recommended by JMT, but can i find one that fits?
- C2/C3 4x Elna Cerafine 470µF/25v
- C4 2x Wima MKS-2 6.8µF/50V
- R1 2x Vishay/Dale 1K 1% 1/8W resistor
- R2 2x 500K to 1M resistor depending on value of pot
- ALPS blue velvet pot, there supposedly exists a 50K version of this, but all i can find is the 100K at angela.
- R3 - R6 gain set to +13
-R3 – 332 ohm
-R4 – 4.75K ohm
-R5 – 2.49K ohm
-R6 – 221K ohm
- R7 50 ohm resistor
- R10, i've gotten two recommendations for this one 100 ohm, and 1K, those are pretty different and i'm not sure which is the right value.
- Cascode set from tangent for biasing op-amp into class A
- 3x EL2002 buffers
- 2 RCA phono input jacks with insulating nylon washers
- 1 neutrik locking output jack
- Blue LED with appropriate RLED value (probably 2.8 mA of current)
- Texus instruments rail splitter
- D1 or D2, from what i gather, you use one of these for reverse power hookup protection, but i think i've seen both of these used on picture on this forum for some reason. Anyone know why?
- Pactec LH57-200 case
I think that's just about everything, with the things i am unsure of noted as such. Also i liked the volume knob that tangent used on the meta42 he constructed in the hammond case, anyone know the model number of this?
Probably the thing i am still most unsure of is what i should buy to power this thing. Since i'm using 25V caps i think that means i can use a power supply of up to 50V which i obviously will not do. I was thinking that 18V would be good, but even if this is the appropriate voltage for my setup, i do not know how to power this thing from the wall. I'm not really worried about batteries, so i don't have to throw them in there in conjunction with the wall power if it is more difficult.
-R3 – 332 ohm
-R4 – 4.75K ohm
-R5 – 2.49K ohm
-R6 – 221K ohm
- 3x EL2002 buffers
