trose49
Banned
- Jun 8, 2005
GET A LINE OUT DOCK AND SKIP THE VOLUME CONTROL f you can!
Think of it the amp in the IPOD is the weak link. When you turn the volume all the way up you are introducing "more disitortion" in the signal since none of the signal is distortion free even though you may not hear it with your IEMS or cans it's there. Now when you amplify the less than perfect signal the distortion is also amplified. The louder you push the IPOD amp the more distortion in the signal. SO turning your volume to as close to the line out volume tend to give the best results IMO. usually about 70% but this also depends on how you encloded the files, if your using soundcheck, mp3 vs acc Rockbox etc.
If you get a line out dock you are going to be impressed because the signal is much cleaner offers more detailed lowend and less distortion.
ALL IMO of course others Im sure will chime in with their 2 cents thats why the forums are so great. But try it and let me know. Should sound a bit better and 12:00 ON LOW GAIN WITH iems AND 12:00 ON hIGH GAIN WITH HIGH IMPEDENCE CANS SHOULD SOUND PRETTY LOUD.
in Fact you can almost adjust the volume on the IPOD in reverse. Put your hornet between 10-12:00 and adjust IPOD volume to a good listening level that you enjoy that should dial you in pretty close!
Make sure to set proper gain depending on your headphones?
LOW for IEMS
MED for Cans with Impedence 100-250ish
High for 300+
this is just a ruff guide I sometime listen to my UE-10's that have a impedence of 16 on Med gain if the song is at a very low level.
Gotta play with it. But Volume up to 100% is a NO NO IMO!
Originally Posted by tnmike1 /img/forum/go_quote.gif HUH??? Clarify please. Someone somewhere told me to turn the Ipod volume all the way up, loud as it can go, and adjust the volume on the amp. Now, you are recommending the Ipod volume at about 70%??? OK will try tht too, altho I don't seem tothink I'm getting any distortion with it all the way up. Mine's red. Love it. Blends well with my Ipod's Vaja case and the twisted copper wire of the ALO Jenacryo dock |
LOW for IEMS
High for 300+
