Mercuttio
Key Conspirator in the Quest to Murder Music
- Apr 22, 2005
I actually prefer the sound of the A8000 out of the Sony as an original source compared to the Bifrost 2. Mine is the older version of the DAC though, not the newest version with the twin Ti DACs or whatever they are. I do have a balanced 4.4 to dual mono XLR connection to go from the Sony to the Ragnorak 2's balanced input directly though, and that DOES add a bit to the equation.I appreciate the reply, definitely keeping the Sony on the shortlist and doing a little more poking around the dedicated thread. I see you have the ragnorak/BF2, which is obviously extreme overkill for the A8000, but I was playing around with them on my desktop stack of the Bifrost 2/Jot 2 in order to fiddle around the the lokius eq and found myself not enjoying the sound of the A8000 as much. one of the first headphones/iems i didn't like with that combo
If you forced me to pick between listening to the A8000 out of the Bifrost 2 / Ragnorak 2 combo vs the Sony Walkman, I'd pick the Walkman. It's more musical and natural sounding in that configuration. The Sony into the Ragnorak 2 is as good if not better, but not necessarily worth all the input switching.
At this point I would guess my next upgrade would be to update the DAC in the Bifrost 2- I have heard it is a livelier presentation than the ladder-style one I have in there now. I think that's my weak link. Everyone was very much into the "The Analog Sound" it had when it came out, but frankly my vinyl setups sound cleaner and more precise. Ragnorak 2 however is absolutely killer- genuinely the audio hub of my listening area and just incredible with whatever you plug into it. The speaker output is pretty solid too, though I'm not really taxing that with my little desktop JBLs.
