FiiO XLR 4 Pin to 4.4mm Balanced Adapter LX-4.4M Is Officially Released!
- Home
- Forums
- Head-Fi Special Forums
- Premier Sponsor Forums and Sponsor Forums
- FiiO
- Thread starter FiiO
- Tags
- fiio fiio lx-4.4m
innocentblood
does FiiO make a 4.4mm Balanced to 4-Pin XLR Adapter?
tamleo
- Jul 13, 2010
The 4.4mm male jacks are wildly sold but I have never seen any female one. Except the ports in amps and hiend audio players.Great innovation! About time somebody got around to developing a decent-quality standalone adapter!
Makes my own adapter cables a bit redundant, but no objections from me! lol
tamleo
- Jul 13, 2010
Does the adapter change the impedance of cables or effect the output specs of amps?
Dear friend,Does the adapter change the impedance of cables or effect the output specs of amps?
Will not, don't worry. The impendance of the adapter is very small.
Best regards
Quarzer
- Feb 28, 2017
@FiiO I'm would also be interested in such an adapter. Are you have plans on them?does FiiO make a 4.4mm Balanced to 4-Pin XLR Adapter?![]()
Chuck Dee
Member of the Trade: Chris Cables
- Jan 6, 2013
I would suggest this type of 4.4mm to XLR adpter, plus the cable will introduce a risk of high load/force/moment on the female 4.4mm socket if you accidentally knocked the adapter while an XLR4p male connector and cable was plugged in. Then it's bye-bye to those terminations in the 4.4mm socket and an expensive equipment repair I'd suspect.@FiiO I'm would also be interested in such an adapter. Are you have plans on them?
You would be better off using a 4.4mm to XLRf adapter cable - something with a degree of flex between the connectors to reduce any risk of knocking it accidentally etc.
Chuck Dee
- Jan 6, 2013
They exist. I use them in my XtndR adapter cable.The 4.4mm male jacks are wildly sold but I have never seen any female one. Except the ports in amps and hiend audio players.
Quarzer
- Feb 28, 2017
Very good point. Make a lot of sense!I would suggest this type of 4.4mm to XLR adpter, plus the cable will introduce a risk of high load/force/moment on the female 4.4mm socket if you accidentally knocked the adapter while an XLR4p male connector and cable was plugged in. Then it's bye-bye to those terminations in the 4.4mm socket and an expensive equipment repair I'd suspect.
Hi everybody, why consider FiiO XLR 4 Pin to 4.4mm Balanced Adapter when there are so many of the same adapter from other brand and markets ? Especially when its cheaper ?
Dear friend,@FiiO I'm would also be interested in such an adapter. Are you have plans on them?
No, we do not have the plan on it.
Best regards
M3NTAL
- Oct 8, 2006
Wonder what the Drop adapter was missing compared to this. Options are good I guess.
I have the older ddhifi model where the used Neutrik connector but was 4 times the price (39.95) the new ddhifi switch to a different connection. At 9.99 would give this one a shot.
- Home
- Forums
- FiiO
