Is that a yellow pelican case in that picture? What model?
this case to be very convenient, but better in black!
Slame,you purchased the X7 in another country when you are travelling? But Germany is still to be confirmed now.
Someone tried to use a one of battery monitor? I tried the Battery Monitor Widget Pro. It shows a very strange result.
-380 - -530 - screen on, music stop, do somthing
-33 - screen off, music stop, idle
-80 - screen off, listen to music in stock app. It can be truth I think.
Paulo Abreu , UK is on the list now , you can get 50% off from us with one module you like.
what is your goal?
I tried to measure a consumption in different modes
mowglycdb,Chile is on the list now !
FiiO pls do not ignore, what about Russia?
Hi,
This FiiO news shows X7 different amp modules side by side
http://m.fiio.net/en/stories/435
Enlarging the picture I notice AM3 (labeled 8) seems to have two holes besides USB connection ...
There are balanced headphone amps that have separated outputs to L/R correct? (Newbie question) but AFAIK AM3 will have a single TRRS Output (as A&K)
I ask since I am an interested part, my Angie IEM balanced cable is one of those... Any thoughts?
Regards
it also has 3.5" TRS.
Ah ... Thanks for the information!
[update] Is that 3.5mm a normal single ended connection?
