don't forget to tell us about the results!
FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
1wyseman
- Jan 2, 2016
Since loading FW 1.91...
...in FiiO Music app
play file from SD card
go to equalizer
activate EQ with little blue button on upper right
stops playback (and count-up timer stops)
but play/pause button does not change from II to ►
play only starts again if you turn off equalizer (little blue button)
worked fine before FW 1.91
Any connection?
Anyone else?
Yes, same results in Pure Music.
In other words, the Equalizer doesn't work since I downloaded FW 1.91
EQ I don't like it, after using it the sound becomes plastic!
1wyseman
- Jan 2, 2016
I hardly every use it, but it needs to work, right?!
(I only use my own setting.)
I prefer not to use them!
1wyseman
- Jan 2, 2016
I pulled the SD card out and re-inserted it after reading a few posts back about the problem with storage/USB DAC not working--although I think mine was working O.K. before that.
I pulled it out when the unit was turned off. Should I / may I pull it out and re-insert it when X7 is turned on?
1wyseman
- Jan 2, 2016
But don't you agree that the Equalizer should work on any FiiO X7--you know, $750.00 and all that...
it is important how it works!
Sonic Defender
Then you may not have been using it properly, or it was a very poor equalizer. A properly implemented and used EQ should not do that to the sound. Something was not right.
warrior1975
- Dec 5, 2013
Yes absolutely. Also, when removing your SD card, you should have the device turned on and unmount through the storage settings.
- Jan 30, 2011
go to equalizer
Any connection?
Anyone else?
Doesn't do that on mine - EQ works exactly as it is supposed to. Maybe reflash 1.91 and if that doesn't work, contact FiiO directly.
Oh and the comment from the other guy about it sounding plastic after EQ - no, sorry. I'd suggest learning how to EQ properly, and maybe take smaller more subtle steps. It also helps to know what you're EQing and why. For frequency bands, google interactive frequency chart - it is very helpful.
warrior1975
- Dec 5, 2013
What do you mean Gosod by plastic sounding?
I'm not a fan of the Fiio stock eq, but it does improve the sound.
You guys received the notification for FW 1.91 when connected via wifi?
warrior1975
- Dec 5, 2013
I did. This is the recent update for one thing? Forgot what for, but it was something I didn't use. Just making sure I'm not missing anything.
mowglycdb
- Nov 29, 2011
AM5 module support
Total: 14 (members: 0, guests: 14)
