http://tieba.baidu.com/p/3925490142
Some information copy from Fiio Official Tieba in chinese, I translate to english
外观造型及结构接口:
三维尺寸: 128mm X 64mm X 16mm.
Size : 128mm X 64mm X 16mm.
显示屏: 4英寸IPS显示屏,分辨率800*480
Monitor: 4" IPS Panel Display, Resolution 800*480
机身材料: 全航空级铝镁合金,CNC一体化成型加工工艺。表面阳极拉丝/喷砂氧化处理。10 万级钻石切边工艺。
Chassic Material: Aircraft Level Aluminium Alloy, full CNC machining. Surface Anodized & brushed, Sandblasting processing. Diamond trimming processing.
重量: 不超过250克。
Weight: less than 250g.
按键: 全功能硬件按键,包括电源,播放暂停,前进/后退,音量加减。
Physical Button: Full function buttons include: Power , Play/Pasue , Forward/Back , Volume
接口: 3.5mm耳机接口,3.5mm线路输出 (LO)接口,3.5mm同轴数字输出接口,平衡输
出接口(可选),11PIN Micro USB接口 (带底座扩展功能)
Connector: 3.5mm phoneout, 3.5mm lineout (LO), 3.5mm spdif coaxial out, Balanced output (Optional), 11pin MicroUSB (inclube Docking extend function)
系统与软件功能:
System & Software function:
基于安卓4.4系统。
OS base on android 4.4
独立的HiFi引擎技术,完全不受安卓系统底层对音频格式的限制。
Dedicated HiFi engine technology, Playback music file format will not limit by Android System Framework limition
独立的音乐播放APP。
Dedicated Music audio player APP
支持第三方音乐播放APP,如网易云音乐等,以实现歌曲在线下载,歌词/封面自动匹配等高级功能;
Support third-party audio player APP, User can using third-party app to listen music online streaming and other music playback function
支持经过验证和许可的第三方安卓APP的安装和下载;
Support certificate verified third-party android app install and download
支持DLNA播放,支持NAS播放;
Support DLNA playback, Support NAS Streaming playback
支持第三方的桌面/壁纸美化APP;
Support third-party UI / Background Image App (don’t sure this meaning launcher)
支持手机遥控;
Support remote by MobilePhone
支持自动OTA推送系统升级;
Support System update by OTA mode
音乐播放能力:
Audio player function:
内置的音乐播放APP支持
Default audio player APP support function:
DSD/DXD/DTS/PCM/WAV/WMA/APE/FLAC/ALAC/AAC/OGG/MP2/MP3等格式。
DSD/DXD/DTS/PCM/WAV/WMA/APE/FLAC/ALAC/AAC/OGG/MP2/MP3 Music format
采样率/位深硬件原生支持到384kHz/32Bit. 软件支持到384kHz/64Bit.
Hardware Native support up to 32Bit / 384kHz playback, software decode support up to 64Bit / 384kHz playback
DSD支持到DSD128硬解,支持ISO直接播放.
DSD playback support up to DSD by Hardware Native, support DSD iso file playback.
对任何不支持的音乐格式或者采样率,均可通过安装第三方APP来解决。
User can install third-party audio player APP to playback all non-support music format or non-support sample rate file by Default audio player
由于基于安卓的开发平台,RK3188的强大运算能力,以及DAC对383kHz/32Bit的硬件支持能力,理论上没有X7不支持的音乐格式了。
Due to android software framework, RK3188 cpu powerful processing power and DAC chip 32Bit / 384kHz native convert function, X7 non-support audio file format is very rare.
系统存储信息:
内置32G 高速FLASH内存;
Onboard 32Gb Flash Memory.
内置512M高速程序运行RAM;
Onboard 512MB RAM (Confirmed upgrade to 1GB RAM)
外置TF卡槽,支持最高128G。理论上支持未来的256G/512G TF卡;
External Memory MicroSD slot support, support up to 128Gb MicroSD card. Feature support 256Gb/512Gb MicroSD card
支持云存储;( 需要等后续通过固件升级支持)
Support Cloud Storage (This Function support in future update firmware)
支持DLNA网络播放;( 需要等后续通过固件升级支持)
Support DLNA audio playback (This Function support in future update firmware)
支持NAS网络播放;( 需要等后续通过固件升级支持)
Support NAS streaming audio playback (This Function support in future update firmware)
有线/无线连接:
Network / Wireless network support:
支持2.4G WiFi;
Support 2.4G Wifi
支持蓝牙音频播放;
Support bluetooth device playback
支持USB 2.0数据连接;
Support Data transfer by USB 2.0
支持USB 2.0 USB解码,支持192K/24B 异步USB解码;
Support USB 2.0 USB DAC for PC, support up to 24Bits/192kHz async USB DAC function.
支持底座扩展;
Support External Docking.
基本硬件配置:
Based Hardware specification:
主控: 瑞星微RK3188. 采用28纳米半导体先进制程工艺;4核1.8G处理器。
CPU: Rockchip RK3188, 4 Core 1.8ghz processor
RAM: 512M (Confirmed upgrade to 1GB RAM)
内置存储: 32G
ROM: 32G
外部扩展: 128G TF卡。
External Storage Extend: 128G MicroSD
DAC芯片: ESS9018 8通道 384K/32B DSD硬解芯片。全球目前性能最高,价格最贵的DAC
芯片;备注:非手机厂家所用的ESS9018K2M解码芯片;
DAC Chip: ESS9018
I/V转换: 待定
I/V : TBD
低通滤波: 待定
LPF: TBD
电压放大: 取决于不同的配置;
Gain AMP: Depend on different module
电流放大: 取决于不同的配置;
Current AMP: Depend on different module
内部电池: 3700mAh不可更换电池;
Internal Battery: 3700mAh, NOT replaceable.
续航时间: 取决于不同的输出功率配置/接口。最长12小时,最短5小时;
Battery Life: Depend on output module/interface. Max. 12hrs, Min. 5hrs
充电电流: 大于500mA, 推荐2.0A电流以获得最快的充电速度。
Recharge: More than 500mA, Suggest using 2.0A to recharge
标准配件:
1,数据线;
2,清水套;
3,屏幕保护膜;
原厂独立配件:
1,各种配套平衡耳机线;
2,各种耳放模块;
3,充电底座耳放;
4,定制的高端耳塞;
发布计划:
Released Plan:
8月7号香港音响展做静态展示。
August 7 : Dummy display on HongKong Audiophile show.
9月13号广州耳机展有新品发布会;
September 13 : Product Released meeting on Guangzhou Headphone Show
9月18号北京音响展有产品展示;
September 13 : Product Tryouts on Beijing Audiophile Show
预计9月底针对VIP用户和老客户优惠发售;
Estimate In late September, Discount Promotion for VIP user and post-customer
计划10月全国上市。12月圣诞节前全球发售。
Estimate October, Release in China,
Estimate December before Xmas , Release in world
