My screen has been acting funny for quite some time now. When I try to press the keys "N" and "H", it will go crazy and spam "JJJJJJJJJJJJJJJJJJJJJ" or "GGGGGGGGGGGG" instead.
Which makes it REALLY difficult to type in. Above you can see a test in parts of the screen that go absolutely bonkers, It's all supposed to be very similar patters. With the wonky touch controls though, the pattern breaks and becomes distorted. As you can see with the middle of the first picture, and the second X. After those, in the third picture, the second half of the squigly line pattern completely breaks then it does so again in the last two squigly lines.
It's really aggravating to use sometimes, especially when searching for music with these characters. Please FiiO, if you can read this, fix this crappy little player. I know it's the software. It's worked fine with certain updates in the past before.
Hi RebeccaSugar,
Did you try to wipe the cache & data on X7 before ? if not ,please kindly try it first.
[size=large]How to wipe the cache & data on X7? [/size]http://fiio.me/forum.php?mod=viewthread&tid=41364
