FiiO X3ii transfer speed
Apr 6, 2020 at 9:06 AM Thread Starter Post #1 of 4
Grado Diesel
Just picked up a new computer and started loaded CDs to FLAC with dBpoweramp. I’ve noticed when copying high def files to my X3ii it’s SUPER slow - like 700kbs-5mbs. Is that because the USB port on the X3ii is not 3.0? Would it be faster to take the micro sd card out and stick it in a usb 3.0 card reader?
Apr 6, 2020 at 9:14 AM Post #2 of 4
Yes. I think it is almost always faster to use a card reader in a PC. But there are a lot of fake cards and slow cards so you will have to try and see.
I also set my FiiOs not to auto update music library so the index never gets built but it also accesses the card in folder mode faster.
Apr 6, 2020 at 9:25 AM Post #3 of 4
Yup mines set to manual. Can I delete the index? I’ve built em before.
Apr 6, 2020 at 11:01 AM Post #4 of 4
I don't know, probably not. I think you can force a rebuild but I don't know if there is a way to purge the index. There are some FiiO people on the forums but usually whatever I buy goes out of support within a few days so there isn't a lot of help.
