C97DDR
- Aug 21, 2016
I'm not worried about the software, there are bound to be some problems with a newly released product which will be fixed with time. When you mention the part about bluetooth (see bolded section in quote) is he referring to the process of pairing a wireless bluetooth headset after disconnecting a wired headset (vice-versa)? Since I mentioned the bluetooth feature, I'd be interested in knowing how well the 2nd Gen X1 starts on and off in the car.
Also, does anyone know if the new X1 has the ability to search through a library of songs like its original did in the last firmware update (2.0)?
Yes, he means "the process of pairing a wireless bluetooth headset after disconnecting a wired headset". But the other way is ok, connecting your wireless headphones via cable because the battery is dead. The problem, according to him, is when you start using the wire/cable and then you switch to bluetooth and take the cable off.
