From where can I check the firmware I have?
Also, I've observed that mine does not charge fully, to 100%
Specifically, I fully charge the case, I can tell because the main light on the front of the case is not pulsing anymore. Then I place the earhooks inside and I leave it overnight. In the morning, the charge level is less than 100%, usually around 97 - 98%. If I remove them and place them back in, they fully charge. I've done a factory reset, once, but it didn't fix the issue.
Anyone else observing something similar?
@FiiO , any ideas?
