frosty5689
- Apr 30, 2017
That will depend on the bend of the adapter and what the original cable that came with the IEM bend is like. Also the shape of the IEM I guess..I'm not clear whether you use them in combination with the UTWS5? I mean, the adapters add to the length so I wondered if the hooks are not ending up being to far back, reducing comfort.
drftr
For my IE8i the original cable's connector was quite long, although it was straight because there was no earhook. I got an adapter that has a slight bend to use with UTWS3. Worked out quite nicely
US $9.34 11%OFF | MMCX Converter 0.78MM Headset Converter Plug 0.78mm to mmcx mmcx to qdc JH EXK ie8 HD650 MH334
https://a.aliexpress.com/_mN4hGWW
MMCX is really nice as an adapter as it can rotate. So if the angle is incorrect horizontally you can always rotate it. I would say angled adapter really helped with making it fit with the UTWS5 earhook.
