The question is: is it available anywhere?Is the 0.78mm version available for shipping to Canada yet?
[FiiO UTWS5] True Wireless Bluetooth Earhooks as Usual,Coupled with Independent AK4332 DAC
- Thread starter FiiO
- Tags
- fiio fiio utws5
- May 3, 2009
Pre ordered the UTWS5 to upgrade my UTWS3 I am using right now. Hope to find a noticeable upgrade with the already good UTWS3 + UERR pairing
umermajeed
- Jun 8, 2010
I saw the mmcx version available through Ali express but not the 0.78mm one.The question is: is it available anywhere?
Besides some people have received theirs so it must be available somewhere.
drftr
Just curious when FiiO is moving to build the bluetooth/DAC/amping parts into their headphones so we're finally done with all this loose stuff that can only break down. Certainly their latest models are tiny enough to expand them to normal size again, allowing fantastic ergonomical support by the ear, and having enough space for the electric components. I think I'll be holding off until they're truly wireless. It's almost 2022 and many have gone there before. I'm actually having a very touch time moving away from my Sony WF01000XM4 to much better sounding IEMs (should be easy!) because of the ultimate freedom they deliver with incredible battery life and comfort at the same time.
drftr
drftr
frosty5689
- Apr 30, 2017
You're looking at the wrong product then. I'm sure FiiO will come out with their own TWS IEMs in due time. But this product is aimed at a niche market of people who don't want TWS and want to use their existing quality IEMs without wires. I find this product very economical compared to buying TWS every year or two. My good IEMs dont need to change, just the adapter to get new technology in Bluetooth audio.Just curious when FiiO is moving to build the bluetooth/DAC/amping parts into their headphones so we're finally done with all this loose stuff that can only break down. Certainly their latest models are tiny enough to expand them to normal size again, allowing fantastic ergonomical support by the ear, and having enough space for the electric components. I think I'll be holding off until they're truly wireless. It's almost 2022 and many have gone there before. I'm actually having a very touch time moving away from my Sony WF01000XM4 to much better sounding IEMs (should be easy!) because of the ultimate freedom they deliver with incredible battery life and comfort at the same time.
drftr
frosty5689
- Apr 30, 2017
The UTWS3 also had less stock of the 0.78mm version. Have you considered getting a 0.78mm to mmcx adapter? You have much more adjustability with the mmcx connector as it allows free rotationI saw the mmcx version available through Ali express but not the 0.78mm one.
drftr
I don't think you got my point. I'm sure more upmarket brands are looking at exactly this. They're adding $200-$300 cables and I'm sure they'd like to get rid of those.You're looking at the wrong product then. I'm sure FiiO will come out with their own TWS IEMs in due time. But this product is aimed at a niche market of people who don't want TWS and want to use their existing quality IEMs without wires. I find this product very economical compared to buying TWS every year or two. My good IEMs dont need to change, just the adapter to get new technology in Bluetooth audio.
drftr
drftr
Correct, but unfortunately MMCX is considered among the worst connectors because they easily break. The 2 pins however sometimes simply fall from the cable. Seems even worse to me. That's probably the reason that there's now at least 5 different connector types developed by other brands that all aim for marketshare. Terrible situation for us buyers if you want to cable-roll or... buy FiiO Blutooth earhooks...The UTWS3 also had less stock of the 0.78mm version. Have you considered getting a 0.78mm to mmcx adapter? You have much more adjustability with the mmcx connector as it allows free rotation
drftr
frosty5689
- Apr 30, 2017
You mean brands that make a thousand dollar IEMs turning them into TWS? Thanks, but no thanks. Not spending more than 300 dollar on a TWS, these things become obsolete much faster than traditional IEMs due to the nature of the technology.I don't think you got my point. I'm sure more upmarket brands are looking at exactly this. They're adding $200-$300 cables and I'm sure they'd like to get rid of those.
drftr
frosty5689
- Apr 30, 2017
They are pretty tight, so if you bend or step on it. Sure it will break. I haven't experienced normal use breaking on me. If you drop or step on IEMs. They will break.Correct, but unfortunately MMCX is considered among the worst connectors because they easily break. The 2 pins however sometimes simply fall from the cable. Seems even worse to me. That's probably the reason that there's now at least 5 different connector types developed by other brands that all aim for marketshare. Terrible situation for us buyers if you want to cable-roll or... buy FiiO Blutooth earhooks...
drftr
The amount of power these UTWS5s have compared to my Shure adapters is unreal. They can definitely get far louder than my ears can handle. The Shures can’t.
dasadab
- Nov 14, 2016
Any available for order yet?The amount of power these UTWS5s have compared to my Shure adapters is unreal. They can definitely get far louder than my ears can handle. The Shures can’t.
Not sure got mine from Ali express. Took a couple weeks to get here.Any available for order yet?
FiiO Willson
Sponsor: FiiO
It is completely possibleSo... This is a stupid thought.. Does the UTWS5 case charge UTWS3 adapters? And vise-versa? The output ratings are the same, the shape and contacts are the same. Good to know if the UTWS3 case will charge my UTWS5 in a pinch. Even though it is bulky enough to just carry one of them.
But you are recommended to use the UTWS5 case for charging, UTWS5 has made some changes to be more stable。
FiiO Willson
Sponsor: FiiO
0.78mm Version will available 2~3 weeks later.Is the 0.78mm version available for shipping to Canada yet?
Total: 3 (members: 1, guests: 2)
