Hello , Am3.5Prowill be sold only in China!?
Me too, I just received a Q5 (used from another HeadFi’er), and while its OK “without EQ”, and I like the build quality, will definitely not get the Q5s if it doesn’t support HW para EQ either.for me that would be a deal breaker if there is no system wide eq
some of my earphones will sound trash whitout eq i think i have to stick whit my es 100 when there is no (hw para eq)Me too, I just received a Q5 (used from another HeadFi’er), and while its OK “without EQ”, and I like the build quality, will definitely not get the Q5s if it doesn’t support HW para EQ either.
At this point I’m being forced down the DAP route..
I wish ES100 was made in a good case with a better battery - no gimmick “90%” option. I’m surprised other manufacturers not entering into similar realm (also BTR suffers same ergo/case issues, arguably less features). It seems like would be good market for such.. easily a $200 purchase for me with ergo and battery improvements. Thrown in a newer DAC too or DLNA, whatever.some of my earphones will sound trash whitout eq i think i have to stick whit my es 100 when there is no (hw para eq)
Because it is useful, consider these use cases.Why would the Q5s have an EQ? That is the job of the source to provide. Yes I used eq all the time on my phone which went to the Q5, or with my laptop to the Q5. This isn't a DAP, it is an amp and a DAC so no need for an eq integrated into it. Not sure where people got the idea that it would have equalization ability?
Dude, the Q5 has no interface, you can't run anything on it, it is a hardware device. How would you install and interact with an equalizer through the Q5? I have no idea what you mean. It is not a DAP. Are you suggesting that built into the Q5 would be an equalizer that is exposed to the different possibly sources? I am not saying that is impossible (maybe it is) but it is certainly not common for such a device and I don't think that FiiO suggests the Q5 has this ability. And it is not a DAP at all, it is a hardware amp/DAC and it relies on a properly featured source.Because it is useful, consider these use cases.
- Not all sources can EQ
- Can EQ same from all sources
- Centralize EQ from same device / different headphones
Since MY goal, and such seems to be a common goal, of trying a Q5 was to avoid a DAP (because I don’t want multiple screens), well.. shucks.
Then Q5 is a true half-DAP, other half is phone/source agnostic.
True that, but I can see a case for a hardware EQ, as it could be defeated to lower any possible (albeit likely tiny) influence on the sound quality. Still, I am very happy with the Q5/Q5s as is as all of my possible sources already provide access to really well implemented equalizers.Most people prefer a hardware device which does not color the sound. FIIO follows that philosophy in this device too I guess. Hardware EQ would include components which would add or change native sound fed into the device. They emphasize that concept by giving us the option of AM3D amp module. THX AAA configuration is popular for such kind of "wire gain" with very low harmonic distortion. I think EQ should be a dedicated function of the source player. Q5S is an AMP/DAC. Almost all high end home amplifiers do not have tone controls build into them.
If hardware did not “color the sound”, then all DACs would be the same. Clearly this is not something ‘audiophiles’ hold true, per the variety in reviews: everyone is searching for their own flavor. Whether it be DAC, transducers, AMP (eg. tube rolling), tip rolling, cable rolling, etc.Most people prefer a hardware device which does not color the sound. FIIO follows that philosophy in this device too I guess. Hardware EQ would include components which would add or change native sound fed into the device. They emphasize that concept by giving us the option of AM3D amp module. THX AAA configuration is popular for such kind of "wire gain" with very low harmonic distortion. I think EQ should be a dedicated function of the source player. Q5S is an AMP/DAC. Almost all high end home amplifiers do not have tone controls build into them.
The Monoprice portable THX amp/DAC has PEQ, Dirac, filters and more built into the amp and accessible through an onboard menu. I don’t see why the Q5s was built the way it is without access to it’s sound functions without an app. Some people want to use an amp like this one for portable use (as well) as an amp with a transport attached. That would have been my usage scenario.Dude, the Q5 has no interface, you can't run anything on it, it is a hardware device. How would you install and interact with an equalizer through the Q5? I have no idea what you mean. It is not a DAP. Are you suggesting that built into the Q5 would be an equalizer that is exposed to the different possibly sources? I am not saying that is impossible (maybe it is) but it is certainly not common for such a device and I don't think that FiiO suggests the Q5 has this ability. And it is not a DAP at all, it is a hardware amp/DAC and it relies on a properly featured source.
I realise that the ES100 has built in hardware equalization ability, but the Q5 does not and I would personally prefer the flexibility of a software based eq, but I guess if people want this, perhaps it is a feature that FiiO will put into a future product. Sorry for misunderstanding your intent, my bad.
I do realize that the way the EQ is implemented in the ES100 allows for a great deal of flexibility so that kind of renders my point moot. Maybe I will become a fan of built in hardware equalizers.
Fair enough, but you have to pick your battles perhaps, and if I had to guess FiiO opted to spend their R&D on the rock solid DAC and amp implementation, in addition to the very competent Bluetooth. Is there more to be brought out? Perhaps, but regardless, FiiO produced an astounding, top-shelf sounding all in one, versatile device and for that they have my deepest respect. Yes, it isn't everything, but I think it is more than enough.The Monoprice portable THX amp/DAC has PEQ, Dirac, filters and more built into the amp and accessible through an onboard menu. I don’t see why the Q5s was built the way it is without access to it’s sound functions without an app. Some people want to use an amp like this one for portable use (as well) as an amp with a transport attached. That would have been my usage scenario.
