bflat
Anybody get 96 kHz working on optical? For me I get nothing - no sound, but the rate indicator shows yellow.
Dear friend,Anybody get 96 kHz working on optical? For me I get nothing - no sound, but the rate indicator shows yellow.
Dear friend,Firmware V0.39 appears to have broken the ability to turn the battery charge OFF in Bluetooth settings. The software switch is in the off position, but as soon as I connect the Q5s by otg micro B cable, or to my desktop the Q5s will draw a charge from either my phone or desktop. Yes I have tried the previous hack steps. @FiiO Is it possible to downgrade back to 0.37 without bricking the device?
Working just fine on my end. In fact I mainly use mine with optical 24/96kHz on my PC because I can't be bothered to go through the procedure of turning off charging. Just make sure your cable is all the way in, optical connections are sometimes finnicky. Also, the Fiio adapter doesn't click in place like a normal 3.5mm jack, so you have to make sure it stays where it's supposed to be.Anybody get 96 kHz working on optical? For me I get nothing - no sound, but the rate indicator shows yellow.
Dear friend,
The charge on/off option is for USB DAC function in computer. When using with Android mobile phone, you could try our CL06 or ML06 for help. And yes you could downgrade to previous firmware if you prefer.
Best regards
I checked when connected to phone and charger. In these cases behaviour is exactly the same as in v.0.32 and 0.37. When switched off by bluetooth or first switch device on and then connect with double otg cable then there is only about 2 mA going to device so NO CHARGING.Can anyone else check if the charging OFF setting works with the new firmware when connected to PC?
Hi could you please kindly compare the SQ between AM3E and AM3D. ThanksCompared to the q5s (AM3E), the m11 sounds a bit easier across the entire range, with less detail and less bass control. The sound of Q5s with the AM3D module does not make sense to compare with the M11, this is a completely different level.
Dear friend,
Please check whether the volume is too low? Or check via other 96kHz file? I checked again just now and 96kHz work in optical input for Q5s fine.
Best regards
I just installed FW v0.39.
Installation went smoothly, following the pdf instructions.
"Charging Off" setting works as supposed (as before) with PC USB connection.
Connected to phone using CL06 - no back-charging.
So no issues for me at the moment.
Still missing that long press on a hardware button for setting "Charging Off". Maybe on next firmware?
On 39 software too. No problems connecting to Fiio App on my iPhone to disable charging. However, once disabled, the Q5s still shows charging when in USB mode.
Yep, same on my device. Seems some devices work, and some don't on V0.39. What otg cable do you have and what amp?
Standard micro USB cable connected to my Macbook.
