LoveMusicEveryday
@FiiO
Some usability issues that I think should be addressed in a future firmware:
When the Q5s is turned on, the front blue led lights up with no input connected (USB, Bluetooth or other device). This is different than Q5 where the front led lights up only when input connected.
So it is counter-intuitive and a bit confusing to have a blue light on when unit turns on, then press the Bluetooth button for Bluetooth to activate with the same blue light blinking then resuming its "on" state.
This way the blue light is used in three different situations:
1. Unit ON
2. Bluetooth ON / SBC
3. USB ON / Standard-Res
I think it would be better to use white light or better no light when unit turns on and nothing is connected. Because we already have the "input" side led on, and the mechanical switch on volume, so we know the unit is ON.
And reserve blue light only for Bluetooth connect / SBC.
Wired inputs: white light for standard-Res / yellow for Hi-Res / green for DSD.
Then, as others have noted - in FiiO Music > BT Control - I don't know what's the difference between "RGB Indicator" > "Always" and "Until device". It seems there's no difference between the two settings, or something is not working there...
Maybe "Until device" is meant to say "Don't turn on front LED until a device is connected" but the setting is not working.
Also the captions "Open" / "Close" are redundant because we already have the grey/red on/off switches. Or at least the caption should be "On" instead of "Open" and "Off" instead of "Close".
The setting "Charge" on/off is it meant to work when unit connected to PC or phone only? Because when the "Charge" is off the unit still charges through USB when connected to PC and in use.
Can you let me know how you get the BT Control panel to work? On my iPhone 8 Plus, the BT Control panel showed up on the very first attempt, and then a pairing confirmation to pair showed up and when I confirmed it, the BT Control panel disappeared and never showed up again. Any attempt results in failures. Can any kind souls here help me if you know a trick that would help me to get this BT Control to work on my iPhone? I don’t have an Android phone.
Fiio, please help me as well if you are reading this. Also like others, I would like to see how Fiio can address the back-charging issue when the Q5s is connected to Mobil devices like my iPhone or portable DAP via the USB port.
Thank you in advance for anyone/Fiio for your kind help.
