FiiO Q5, Flagship DAC/Amp, an Dual DAC, USB/Optical/Coaxial/Line in, share the same amp module with X7.
Jan 5, 2019 at 5:05 PM Post #2,718 of 3,173
Shouldn't be any difference. Exactly same DAC for conversion. Blind test, volume matched, same master tracks - I can't hear any difference.
Jan 5, 2019 at 6:12 PM Post #2,722 of 3,173
The q5 has 256 graduations of volume (an iphone has 16) and the q5 can pause/play as well as forward or back a track on my song list. I use an iphone se for my bulk music storage and the ability to keep each unit in a separate pocket is the q5 advantage for me.
Jan 5, 2019 at 8:54 PM Post #2,725 of 3,173
Sound on Q5 , Bluetooth vs optical/coaxial line in, do you guys heard differences in term of sound quality?! Because is just good.
I prefer USB input above Bluetooth personally, can hear the difference done by the BT compression algorithms, especially with metal music with a lot of background instruments.
Jan 5, 2019 at 9:31 PM Post #2,726 of 3,173
Which Bluetooth codec? You realise both are going through the same DAC? How did you test? How did you volume match?
Jan 6, 2019 at 2:45 PM Post #2,728 of 3,173
AM5 gives you more flexibility for both.
Jan 6, 2019 at 8:21 PM Post #2,729 of 3,173
Thanks for the feedback, Brooko. I read in your AM2A review that at the time, "If I had to choose just two modules of all of the ones FiiO has on offer at the moment, I'd probably go AM3 and AM2A" - though I did read some later comments in other threads where you felt the AM2A was too warm. I imagine your tastes changed over time as you had more experience with the modules.
Could you shared your current thoughts on AM5 vs AM2A?
Thanks again.
Jan 6, 2019 at 8:33 PM Post #2,730 of 3,173
Have a comparison in the works for all the modules. Hopefully only a week or two away. Reason I recommended the AM5 over the AM2A to you was that the AM5 has slightly more power, but is cleaner for IEMs - and you wanted one module to do both (didn't you?). I may have mis-read your question?
