Zodler
- Sep 25, 2016
I ordered 4 different cables and combinations. I will be able to test them to see if it works soon.
Then I used this cable and it works. You connect it to the special lightening cable provided by Q5. Not only it works, no charging Q5 by iphone (no blinking white light).
So this solution works but as I said earlier it is not ideal because you are dependent on the special short cable provided by Q5.
A question .!!
Why is nobody making it? 4,4 mm female >> 2,5mm male balanced translator ??? There are a couple of cables that have 4,4 pentacones with a factory-balanced cable. (Senn HD660S / Sony MDR-1AM2) It's so difficult to launch ??? since the reverse is available.
(Fiio does not make, only 2.5 female 4.4 balanced male jacktranslator (BL44) )I do not understand this well ... if we are mixing here with pentaconne 4,4 / Trrs 2.5 outputs ..
Thanks. Maybe it will be good, although in China they do not know how to "sold" it. Unfortunately, it's not good for my wristwatch. In FioO it would be better because the BL44 is of a very good quality. That's why I do not understand why they do not, because they have 4.4 modules / 2.5 modules for them.I have this one and it is nice quality... https://www.ebay.com/itm/hi-end-4-c...-cable-/122908358227?var=&hash=item1c9de8b653
I have FiiO L26 adapter cable and it felt like it could break in any second. BL44 looks a bit sturdier though.
After I bought AM3B module there has been no need for adapters. All of my balanced headphones have 4.4mm cable now.
Dear friend,@FiiO , I got a Q5+AM3B (Japanese market version) but recently the DAC seem like not functioning properly. It doesnt work when connected to 2 of my iPhones. It's showing white light, detected under iPhone About page, shown on FiiO player app but when pressed play, it will hang. Tried on 3 laptops, DAC detected but no sound on the jack when playing music. Can assist?
Hardware ver: 2.0
Firmware ver: 0.5.2
Dear friend,
Please try to reset the Q5 by poking the reset button in the left side to see if it helps first?
When using as the DAC for the computer, the headphone jack doesn't output correctly as well?
Best regards
Had the chance to listen to my HD 6XX driven by the iFi Micro iDSD Black Label, and although I liked the sound, I'm not sure if I like it more than my Q5 / AM3A SE. (I'm still waiting for that balanced cable for the AM3A.)
The iDSD BL had a deeper, weightier, warmer sound with punchier bass, a bit deeper sound stage and smoother high-mids / highs. Q5 was more articulate and drier sounding in comparison. I think I like both
This had me wondering if AM5 module would sound closer to the iFi iDSD BL presentation. Anyone heard both the Q5 with AM5 and the iFi? What do you think?
