[FiiO Q3/Q3 MQA] THX AAA amp technology, 2.5/3.5/4.4mm Output(Good News! Our German Dealer Is Promoting Q3s from May 13 to June 13!)
Jun 27, 2021 at 3:33 AM Post #346 of 565
Yes it is good , nothing wrong with it
I have reviewed long time ago for a Greek magazine and I think that is very good for the money.
Nice coherent and enjoyable sound and tons of power.
I will probably look into it then. The only issue is I have to buy extra lightning to usb cable to use with my iPhone but should not be a problem using with my Samsung tablet apart from the laptop. Let me see. Thanks for your suggestions!
Jun 27, 2021 at 3:38 AM Post #347 of 565
You are welcome.
Just note that I am not sure if is compatible with Android.
I have only tested it with windows PC.
Aug 2, 2021 at 6:28 AM Post #349 of 565
Is there any difference between the 2.5mm and 4.4mm balanced outputs in practice? According to the tech specs they should be the same. Anyone here did a listening A/B test to compare?
Aug 2, 2021 at 6:59 AM Post #350 of 565
They sound exactly the same.
The 4.4mm though is more robust and has better contact and fit.
Aug 9, 2021 at 5:39 AM Post #353 of 565
I got one for my birthday. Love it very much! Works like a charm with my iPhone.
However, when I use it with my Shanling Q1 it drains the Shanlings battery a lot, like 20% in 18 minutes. The charging switch is off. Both devices brand new.
Shanling suggests the Fiio is using power: https://www.head-fi.org/threads/sha...table-hi-fi-music-player.920927/post-16496510
What can I do?
Dear friend,
【RGB light status indication】
Status ON(standby)USB DACLine inLow battery warningCharging (OFF) Charging (ON)
Light colorBluePCM≤48kHz:Blue;
PCM> 48kHz:Yellow;
DSD:Green
BlueRed light flashes every 2sRed light pulses;Constantly on when fully chargedCorresponding light pulses;Constantly on when fully charged
You could check the indicator status for confirming whether the Q3 is being charged? Or you could check whether the problem remains when connecting the Q3 to other device?
Best regards
Aug 9, 2021 at 4:43 PM Post #354 of 565
@FiiO Does Q3 works with the micro USB cable CL06? I have an old Samsung S7, which uses micro USB port (it supports OTG).
Aug 12, 2021 at 3:34 AM Post #355 of 565
Dear friend,
If your mobile phone support USB audio output, the connection could theoretically work. I tested the FiiO X53+Q3 using CL06 and the output works fine.
Best regards
Sep 13, 2021 at 3:40 PM Post #356 of 565
Sep 16, 2021 at 3:04 PM Post #357 of 565
I would love a Q3 mini with a form factor like the Paw S1.
