BobSmith8901
- May 5, 2015
I've just ordered a braided cable designed for a Mavic drone remote control. Looks like it should be a bit neater than the stock cable - it uses right angle connectors.Anyone using custom / third-party micro USB to Lighting cables? If so, can you point me in the right direction? There's a few options on eBay, but not sure of compatibility (I have messages out to the sellers):
- https://www.ebay.com/itm/172325662501?ul_noapp=true (I've bought from him before; would be my top choice, but I'm waiting on confirmation if this would work with the iPhone 8/8+ / newest iOS...gonna guess yes. Unsure if it'd work with non-Hugo equipment...not sure what determines this)
- https://www.ebay.com/itm/382268452284?ul_noapp=true (Item description doesn't mention iPhone 8/8+ and says it doesn't work with non-COZOY equipment, so I'm guessing this option is out)
- https://www.ebay.com/itm/263152465164?ul_noapp=true (Looks to work with different manufacturers, but no mention of FiiO and/or iPhone versions)
Exactly how I use it too.Guys, can i use Q1M2 as a DAC with A5 as an amp through iPhone 8 Plus?
thank youExactly how I use it too.
Just to confirm, it is working. Neutron sends audio to Q1 and Q1 is not charging from the phone.It seems Fiio heard the pleas of every android user begging to pair his budget smartphone with the Q1MK2:
https://fiio-shop.de/en/kabel/404/mm03-micro-usb-zu-micro-usb
Swap the language to german for a lengthy description that condenses into "you now can use the Q1MK2 with micro USB smartphones".
Just in case anybody was tempted to try this- doesn’t work, unfortunately. What Mavic describe as ‘micro-USB’ is actually a proprietary connector.I've just ordered a braided cable designed for a Mavic drone remote control. Looks like it should be a bit neater than the stock cable - it uses right angle connectors.
Sadly, have never seen the DSD light come on. Not sure if it’s a Mac problem.Any Mac users on here, specifically with Audirvana Plus? When I'm using the Q1 Mk2 as a USB DAC I can't get the DSD formats to show up as enabled in the "Preferences > Audio System" section. Similarly if I'm playing a dsf file then I don't see the green DSD light appearing either.
Any ideas?
I've had no problems with A+, and the green DSD light.Any Mac users on here, specifically with Audirvana Plus? When I'm using the Q1 Mk2 as a USB DAC I can't get the DSD formats to show up as enabled in the "Preferences > Audio System" section. Similarly if I'm playing a dsf file then I don't see the green DSD light appearing either.
Any ideas?
Dear friend,Any Mac users on here, specifically with Audirvana Plus? When I'm using the Q1 Mk2 as a USB DAC I can't get the DSD formats to show up as enabled in the "Preferences > Audio System" section. Similarly if I'm playing a dsf file then I don't see the green DSD light appearing either.
Any ideas?
Dear friend,
Have you selected the DOP option in the Audirvana?
Best regards
I did not know I had to do that! Tried it just now and got it working, green LED and all Thank you very much for your help!
