Lifted Andreas
Formerly known as geko95gek.
Any time frame on when there will be a fix for the Windows drivers?
There's been no update in almost a year.
Dear friend,Any time frame on when there will be a fix for the Windows drivers?
Dear friend,Sounds great, enough power as is with my HE400S and I'm waiting on some balanced cables to try too.
But audio cuts out on my iPhone even on IOS 11.3, which was suppossed to solve the issue. This happens even with Blutooth off, all app notifications off, etc.
Anyone else having this issue?
Dear friend,
Would the issue happen when using in the computer? The ios 11.3 you downloaded is the stable version as well?
Best regards
For use with android tablet and iPhone 5 and not planning to go balanced, should I get the MkII over the original? The difference is still 30 :/
How do fiio q1 mk2 sound when compared to the original q1. Is there a huge improvement in the sound quality between mk2 and the original
Hi guys! My father wants a portable, light and small, amp/dac to join his old Fiio X3 2nd gen. Assuming he could only use the amp section, it's worth the purchase? Some other alternative below 200 €/$ ?
Thank you in advance and have a great day!
Fiio A5? It's just a amp
