Dear friend,There is a need for warning message about opening your Q15. I've done it and now i have broken rear glass and probably Bluetooth antenna because it is designed in a phone way. One should hot air front glass with screen, then disconnect screen ribbon (which if you take the screws first and don't mind glass it will get bad), then hot air rear glass, disconnect Bluetooth antenna, and in the last step unscrew 3 mini screws on the bottom of the device. Unfortunately there is no replacement for rear glass
Hi, if you need extra rear glass for Q15, you could contact support@fiio.com for help.
Best regards
