RightMark Audio Analyzer comparison THD Fiio M5 and Fiio X3-2
https://ibb.co/WfL9rP6
Dear friend,
What's the firmware version of your M5?
And you could add the files in M5 to foobar2000 first. Then save the playlist to the root directory of the M5 in m3u format.
Can you get the playlist in the M5 work at that time?
Best regards
Dear friend,With the new firmware i have experienced a few random restarts and some tracks not start to play with
the first play attempt.
Dear friend,On firmware 1.3.2. I added the files in the M5 to foobar, and saved it to the root of the SD card. I keep on getting 'File not found'. The path it creates is just Music\Artist\Album\Song.mp3. Is there nothing before that like external_sd\ or anything like that.
Dear friend,Hello,
I'm facing an issue regarding the headphone remote support
my final audio e3000's control seems to have no effect
thanks
I would like to use the M5 as USB DAC , is there a USB c to USB c cable that will only handle data and not use the phone to charge the M5?
