FiiO M15S Pocket Desktop-Level Player Discussion & Impressions Thread
Mar 27, 2023 at 6:12 PM Post #19 of 917
Mar 28, 2023 at 12:56 AM Post #22 of 917
You say that like it's a bad thing
It's not necessarily a bad thing, but it makes me think of the amount of research and dedication to put into it(Not to mention longevity of their products). I've had a couple of Dac/Amps from FiiO and my intention is not to talk ill of the brand, but most of the time I tend to look for products coming from brands that take a bit more time to investigate and evaluate all chances of improvement.
That being said, I could definitely get this DAP if it fits my needs.
Mar 30, 2023 at 5:37 AM Post #24 of 917
The M15S comes with a cooling stand. Does it have the same heat problem as the M17? My M17 gets pretty warm after 60 minutes without a fan, even with IEM, low gain, WIFI off, screen off. That's why I only use it with the fan in the stand so that there is no heat problem.
Mar 30, 2023 at 7:27 AM Post #25 of 917
I can check it out soon...
Mar 30, 2023 at 9:16 AM Post #27 of 917
Is Fiio releasing devices every month? At least that's what it seems like...
It's been three years since the first-generation M15 release:sob:
Mar 30, 2023 at 9:20 AM Post #28 of 917
Hi, M15S has done sufficient heat dissipation. From our laboratory data, in the case of 40mv output, the temperature of the M15S machine will only rise by 9°C after playing continuously for one hour.
