- Jun 8, 2009
No screen protector? No case?...is that even legal on a dap at this price?
There is one fitted on the back already when you peel off the shipping cover, the front however only has one in the box and isn't that great, I've ordered some from hifigo.No screen protector? No case?...is that even legal on a dap at this price?
Has one on the back pre fitted, hard to see unless you get a camera on it but it's there alright. Ordered the official leather case as a well for good measure.
Does the Fiio leather cover fit with the Glass protector applied on the rear glass?LOL, you're right! I thought I had scratched up the back and now see there is a thin plastic protector on it. I peeled it off and now see a pristine back. Not sure if that's meant to stay on there since the "protector" is pretty soft. I use the leather case always, but could use a recommendation for a front tempered glass protector if anyone has discovered one.
What's up everyone,
I just purchased an Abyss Diana V2, and I'm realizing that my SR25 doesn't have enough juice to run this demanding headphone.
Will the M15 be able to do this? Does it have good bass slam?
I'm deciding between the M15 or the upcoming Astell & Kern Alpha.
It can power the V2, but it won't sound as good as a desktop amp with a bit more power.What's up everyone,
Does the
Ya... Realizing that there was a fitted one on the back from the factory was such a pleasant surprise. I wondered why the back scratched so easily. I pulled off the factory installed one on the back (hard to take off!) And put the other screen protector that came in the box.Has one on the back pre fitted, hard to see unless you get a camera on it but it's there alright. Ordered the official leather case as a well for good measure.
I have not come across this issue of popping noise and I’ve used it for over 100hrs.Hi guys.
I'm thinking of buying the M15 but I heard that there are some popping noise problem that happens while changing tracks with different bitrate which was an issue some time ago. May I ask that does the issue is fixed now? (After several firmware updates) I do really like the overall design and the high power output of the DAP itself but I definitely cannot torelate the popping noise issue so I'm really curious about this.
Thank you very much in advance, and sorry for my bad english.
I've skipped between 44 - 88 - 96 - 192 & single / double / quad DSD and heard nothing.Hi guys.
