Regarding:
fiio-file.fiio.net/M15-ota-20200722.zip - more information if you have not come across yet...
Wian Liu
July 22, 2020 - 5:04AM
Hello everyone, here comes the latest 0722 beta firmware for M11/M11Pro/M15.
Notice: this version is still under beta testing phase, if everything works fine, we will release the offical firmware next weeks. And if you have any problem, please feel free to contact us at support@fiio.com. Any suggestions would be greatly appreciated.
Download link:
M11->fiio-file.fiio.net/M11-ota-20200722.zip
M11Pro->fiio-file.fiio.net/M11Pro-ota-20200722.zip
M15->fiio-file.fiio.net/M15-ota-20200722.zip
Update note:
1. Added tracks sorting within playlists (now the playlists sorting, which is based playlist names, and tracks sorting within playlists are controlled independently);
2. Improved the MQA identification and playback, fixing the issue where a part of the MQA track would be missing when switching tracks, and also added MQA playback indication on the status bar;
3. Improved the issue where the folders loading would be slowed down when the "Hide un-scanned folders" option is enabled in Scanning settings;
4. Fixed Sony Hi-res application can't be played;
5. Miscellaneous improvements.
Wian Liu:
Here is the reply from MQA: The best method for driving an oversampling DAC chip is to fully unfold the MQA to its original sample rate and then upsample it with filters optimised by MQA for that DAC chip. This guarantees the correct time response for the MQA signal by avoiding the use of the DAC's built in filters.
Hello everyone, for the MQA indicator, we have been required to show the original sample rate in the status bar. All the MQA files are still decoded by MQA library as before.
It means if your MQA file's original sample rate is 352.8k, then it will show 352.8k just like my attachment; if your MQA file's sample is 96k/44.1k, then it will show 96k/44.1k.
Hi, we don't change the version code in the beta version, you can check the Kernel version, it should be Jul 22.
For Tidal, please update to the latest version of Tidal to see if it works.
