[FiiO M11 Plus LTD/M11 Plus] THXAAA-78,Android 10, 2.5/3.5/4.4 Powerful Output/4.4 LO output, Dual AK4497/ES9068AS DAC chips, 4GB RAM,64G Flash
Aug 16, 2021 at 10:13 PM Post #841 of 2,990
Oh I should add, that isn't a "poor me", in case it came off that way. I chuckled when I saw it this morning. Just thought I’d share w/ people who would get it! I’m sure there’ll be other opportunities if I -really- want to get one… and that DX300 does look pretty sweet. Big jump in price tho :D
I understand. The dx300 is still in my Amazon "save for later" cart. *processing* 😅
Aug 17, 2021 at 7:28 AM Post #843 of 2,990
Hello,
Iam trying to connect the M11 plus to my oneplus 8 pro in Bluetooth dac mode but the connections is lost in next 1 second, without displaying any error messager.
Anyone had this issue.
Thanks!
Dear friend,
Do you mean the BT receiving mode? Please check whether this video could help?
Best regards
Aug 17, 2021 at 7:30 AM Post #844 of 2,990
My phone has settings to switch the temperature. Can this be added to the M11+ in a future firmware update? :alien::slight_smile:
Dear friend,
We will report to the engineer for assessing this feature first. Thanks for the feedback.
Best regards
Aug 17, 2021 at 7:59 AM Post #845 of 2,990
Dear friend,
Best regards
Hello,
Yes, BT receiving mode, sorry...
The Fiio shows connected just for one second and them it shows "waiting for connection..." again.
I will try with another smartphone to see if there is something wrong with my phone.
Thanks.
Aug 17, 2021 at 9:53 AM Post #847 of 2,990
Just realized Ive been buying Fiio players and amps since I first discovered the Fiio Fujiyama E06 and headphone amps in general.☺️ It's still on my shelf of audio products. (Need to get Ebaying) 💰😆
Aug 17, 2021 at 12:40 PM Post #848 of 2,990
1. Netflix not working (I hope it will be a firmware upgrade later)
2. Android 10 desktop mode not yet available (Ha, this is so sad. I was very much looking forward to this, I hope this will also be a firmware upgrade)
3. It's quick (useful for enter)
4. But heavy and thick
5. Offline playback works well after Tidal down
(Good to listen to while walking outside)
6. Satisfying sound quality (Fiio 'all to dsd' mode listening with Tidal app)
7. It is quite convenient when connecting a Bluetooth mouse
Aug 17, 2021 at 3:01 PM Post #849 of 2,990
Hello,
Thanks.
Ok, the wifi must be off.
So I tried this mode and the sound quality is so better, how can it be explained? The files are the same one my phone, and the player app the same.
My Sundara are dancing...
But sometimes the Fiio freeze's, I don't now why.
Thanks!
Aug 17, 2021 at 9:32 PM Post #850 of 2,990
Same lol. Amazon shows "2 left" as well, I wonder if it'll last the night? I've picked up a few Fiio products. First was the E17K DAC. That got tossed tho. Battery wouldn't hold a charge & it started putting out quite a bit of static.
Dumb question. How does the all to dsd mode benefit the music? From what I've read about it, its different format, so doesn't it just recompress whatever file you have, then spit it out as DSD format? I don't know if you're losing any bits in the conversion, but its not going to make up anything thats missing? Different story if you're ripping a CD to DSD, instead of AAC (Sadly as I did w/ all my music before I learned there was something out there better than iTunes)
Aug 17, 2021 at 9:56 PM Post #851 of 2,990
I too would like to know. I never did the required reading. Maybe @FiiO can tell us?
Aug 17, 2021 at 10:03 PM Post #852 of 2,990
found this in a quick search:
The ‘All to DSD’ setting, unsurprisingly, takes all PCM audio files and converts them to DSD before amplifying them. This has an almost entirely positive effect on the sound the M11 Pro makes, but a terribly deleterious effect on battery life.
Switching on ‘All to DSD’ serves to widen out that slightly small-scale sound stage (which is good), but it’s at the expense of a little of the M11s exquisite timing (not so good).
It also eats into battery life noticeably, so we’d leave it alone
Aug 18, 2021 at 6:05 AM Post #853 of 2,990
@FiiO is there an option in the AK4497EQ to bypass oversampling, that you could add a NOS (non-oversampling) filter besides all digital filters?
Dear friend,
Do you mean that you don't want to use the filter in the AK4497 chip? But the filters effect are coming with the chip so we could not bypass it as well.
Best regards
Aug 18, 2021 at 6:08 AM Post #854 of 2,990
Dear friend,
When All to DSD is turned on, the various kinds of harmonic distortion in music are more uniformly distributed for a more comfortable and fatigue-free experience.
Best regards
Aug 18, 2021 at 8:49 AM Post #855 of 2,990
So... I already have the Fiio M11, but have been thinking about upgrading to M11+ LTD. Bumping up to the Snapdragon 660 & having Android 10, is very tempting. Well, I've had it in my Amazon cart for a week or so while I considered it & tried to justify the purchase. Last night I had to order a few things & saw the M11+ "only had 2 left." (Was 2 for a couple day's). I almost checked out last night, but decided to sleep on it. Well, they both sold last night! Go figure! I guess that's the universe telling me to wait 🤣
im in the same camp except with the m11pro. personally i think ill just stretch this guy out a couple years with some care and save up for something of an actual upgrade all around and not just a sidegrade with this it seems, but it does suck a lot of third party apps no longer have support for android 7, so im missing out on neutralizer/wavelet(at least they dont work for me on the pro). that's my biggest thing, the battery is an extra hour or two longer and so far ive never really been in a situation where its battery life seems limited, i rarely listen for longer than an hour or two at a time anyways
