[FiiO M11 Plus LTD/M11 Plus] THXAAA-78,Android 10, 2.5/3.5/4.4 Powerful Output/4.4 LO output, Dual AK4497/ES9068AS DAC chips, 4GB RAM,64G Flash
Sep 3, 2023 at 11:34 PM Post #2,836 of 2,991
@FiiO Am experienceing Bluetooth problem on My Fiio M11 Plus ESS. After 10 mins the Bluetooth connection becomes heavily distorted until no sound is heard. Restarting corrects this but only temporarily. Latest firmware and softw installed. Are you aware of this issue and is there a way to fix it? My vendor advises a facto reset.
Dear friend,
1. You could try to delete the pairing record in the player and clear the pairing in the Bluetooth devices. Then try to connect again for check.
2. If you have another Bluetooth devices, you could have a check as well.
3. If the issue still remains, the factory restore may be needed.
Best regards
Sep 10, 2023 at 9:01 AM Post #2,837 of 2,991
@FiiO Hi, I see that Snapdragon 660 Supports Aptx Adaptive. Could you please consider implementing this feature? I have utws5 as well and it'd be nice to use it with it.
Sep 11, 2023 at 2:36 PM Post #2,839 of 2,991
On Windows, you can fix it with the driver. When you install the driver, you can disable the safe mode and change the buffer. It is not 0ms but very very low. Perfectly usable to watch Youtube videos and such things. Not usable for rhythm games and such
But almost all DAP have this issue. I have 350ms on my WM1ZM2 which is why i set the adjustment in VLC and PowerDVD
At that time I tried all possible settings, changing buffer or safe mode did not change the delay at all. In my opition there is or was in the past a bug in the Fiio driver and the buffer was not possible to change, hense stable 300ms dac delay with any buffer setting:
  • M11 Plus ESS firmware 1.0.2 (latest at the moment)
  • Tested in Windows 11 with FiiO drivers 5.30.0.18122 and 4.47.0.
  • DAP connected directly to USB 3.2 Gen 2 port using high quality cable.
  • Latency does not depend on bitrate and sampling rate, 300ms for 16bit 44.1k and 32bit 384k. Tested also with 24bit/192kHz rate.
  • FiiO control panel in Windows shows Input Latency 11.67ms and Output Latency 8.50ms (this is probably estimated, the real is 300ms). The buffer size and safe mode do not affect audio latency.
I don't own a Fiio player now. Would be grateful if someone can install the latest Fiio app/driver on Windows to see this problem is fixed.
Sep 11, 2023 at 2:43 PM Post #2,840 of 2,991
@FiiO Hi, any news on future updates to fix airplay, bluetooth and usb dac audio delays on Fiio M11 Plus ESS?
On bluetooth and airplay it is impossible to watch any video. In the usb dac it still works, but the delay in the voice is very noticeable. Give us any spoilers or hope. :disappointed:
Have you found a solution to the USB DAC delay problem?
Sep 12, 2023 at 10:41 AM Post #2,841 of 2,991
Alright, so I have bought a M11 Plus Ltd from eBay, can't wait for it to arrive - what I am wondering is what (if any) are the cool case options? I'm a case nerd on my phone and have several, I like to have something fun and cool looking when I can. The Fiio made cases look perfectly nice, but I like to see what else is available. Anyone have any interesting options?
Sep 12, 2023 at 7:19 PM Post #2,842 of 2,991
I've been using this for a couple of years and can only recommend it: excellent quality materials and workmanship, and after two years it's still like new.
Sep 12, 2023 at 8:30 PM Post #2,843 of 2,991
Great cases here.
https://www.etsy.com/shop/VALENTINUM
Sep 14, 2023 at 12:40 PM Post #2,846 of 2,991
If you own the FiiO M11 Plus, no.
Agreed. I do run my 660S on 4.4 balanced though... Never tried single-ended.
Sep 17, 2023 at 12:46 PM Post #2,850 of 2,991
I can’t seem to get Apple Music to play anything over 48/24 any more. Played an album I know to be 192/24 and it’s sticking to 48/24. It will change for 44.1 to 48 but nothing else. Anyone else noticing this? On latest app version.
