Bypasses SRC.It does? It does Resample? Or it does bypass SRC?
[FiiO M11 Plus LTD/M11 Plus] THXAAA-78,Android 10, 2.5/3.5/4.4 Powerful Output/4.4 LO output, Dual AK4497/ES9068AS DAC chips, 4GB RAM,64G Flash
- Thread starter FiiO
I purchased it from the official Fiio store on AliExpress, 627 € spent in store and paid € 65 to DHL for VAT and administrative costs. A week for delivery from date of order.Anyone has an idea where i can buy online in Europe ? i am in Italy and on amazon.it Euro 1450 it seem too expensive......
monsieurfromag3
Seems to be out of stock now.I purchased it from the official Fiio store on AliExpress, 627 € spent in store and paid € 65 to DHL for VAT and administrative costs. A week for delivery from date of order.
Hey guys! Might be a little late to the party here, but does anyone know about a workaround to make Roon work at all?
I have the device, everything works pretty much fine. I can enable the device in Roon Audio settings, but when I go to play anything, I get "Failed to open audio device".
- Sep 1, 2006
Ok, i know this isnt the question. Just reminded that It makes me a bit upset with Roon Labs everything it plays on any of my Android DAPs, my FiiOs [M6 or X7] and Pioneer 100r, is resampled to 48KHz. So I've swore off using Roon on my DAPs and just use mSDs. Wish they'd license eXtream SD's hi-rez driver [USB Audio Player Pro's driver].
Dear friend,@FiiO Am I reading this right - compared to the m11 pro there’s a newer fpga and upgraded clock for an overall better jitter reduction? This should result in improved SQ.. I’m surprised Fiio hasn’t really promoted these aspects as much, unless I’m wrong...
I also would love to know if the usb dac mode lag has been improved like the m15- I can’t really game or make music with the m11 Pro unfortunately
According to the feedback from engineer, the USB DAC delay is very small in this players, within 100ms.
Best regards
Dear friend,Hey guys! Might be a little late to the party here, but does anyone know about a workaround to make Roon work at all?
Thanks for your feedback. We will report to the engineer and try to fix this problem in next firmware update.
Best regards
Dear friend,
Best regards
Thanks for the quick answer.
I was checking out the changelogs for the firmware updates on the M11 and M11 Pro and I have two questions:
1. How advanced would you say the current (original?) M11 Plus firmware is in comparison to the previous M11s?
It seems they have some features we don't have in this first iteration of the Plus.
2. When do you think you will be releasing the first firmware update + how often do you usually release them?
If you could work with Roon to make the Roon app bit perfect on the player that would be brilliant tooDear friend,
Best regards
At this moment back in stock on Ali: https://www.aliexpress.com/item/1005002702201305.html
BLUDGEON
- Sep 10, 2016
Will this be available in Taiwan?
Anybody know when this will start shipping to U.S. retailers?
Dear friend,Thanks for the quick answer.
Have you got a M11 Plus LTD now? If yes, the latest firmware for it is now FW1.0.1.
There will be a new firmware for M11 Plus LTD at about this month. We could not tell how often we will release new firmware for each products. But we will release the new firmware to add some new features and fix some problem when it is stable.
Best regards
Yes, for more information, you could contact the seller in your city.Will this be available in Taiwan?
Best regards
At about this month.Anybody know when this will start shipping to U.S. retailers?
Best regards
