jsmiller58
Ah. OK, that’s unfortunately more complicated, but I have one of those .
I live in Berlin only windows computers I have access to are windows 7 at internet cafes on which I tried this morning and the setup said it needed a different / newer OS. I have an android phone and a MacBook. This is pretty stupid @FiiO shouldn't be so restrictive with your firmware update requirements. Nothing upon purchase stated I would need a windows laptop to make this device function. Come on guys do better.Only through a Windows computer
To be fair to FiiO the KA17 is functional without the updates, but you do have a good point. It is particularly interesting they chose this route since something like the BTR7 can do updates via the app.I live in Berlin only windows computers I have access to are windows 7 at internet cafes on which I tried this morning and the setup said it needed a different / newer OS. I have an android phone and a MacBook. This is pretty stupid @FiiO shouldn't be so restrictive with your firmware update requirements. Nothing upon purchase stated I would need a windows laptop to make this device function. Come on guys do better.
There are instructions written in one of the download files. Only works on newer windows 10 and above I thinkAh. OK, that’s unfortunately more complicated, but I have one of those . Is there a page with instructions as to how to update on Windows?
Lot of things don't work right which the update is supposed to fix. The device is not necessarily functioning as it should on the previous firmware with many users having issues that ruin the experience.To be fair to FiiO the KA17 is functional without the updates, but you do have a good point. It is particularly interesting they chose this route since something like the BTR7 can do updates via the app.
OK. My experience wasn’t “ruined” without it, but I can understand that yours or someone else’s might have been. Good luck finding a way to update.Lot of things don't work right which the update is supposed to fix. The device is not necessarily functioning as it should on the previous firmware with many users having issues that ruin the experience.
I'm waiting for my KA17 to be delivered, anyway I was reading the firmware upgrade instructions and it's not very clear to me:
"2. Connect KA17 to the Windows computer"
"6. When "Firmware upgrade finished successfully" appears, you can unplug KA17 and then connect the USB cable. At this time, the upgrade pop-up window "Updating, about 3 mins, PLS don’t unplug USB" will appear on the screen of KA17".
So, unplug the KA17 from the Windows PC and then re-connect the USB to the Windows PC for the update?
INITIAL FINDINGS:I don‘t have any clicking sounds, and I just bought the 7hZ timeless ae because I don‘t want to use the equalizer. The Sundara has too little Bass for me when I hear music and the 7Hz is for me the perfect IEM for Rap/Electro.
Did you try to update/reinstall the fiio driver? I had the problem yesterday too but after updating the firmware it works now.after update the firmware volume is kinda low? need to set high gain and 70+ to get a reasonable volume
also the pc software and the one on phone cant see ka 17 anymore
oh yes its the driver, i uninstall the v5.58 and install the v5.62 included in the firmware then update again its fine nowDid you try to update/reinstall the fiio driver? I had the problem yesterday too but after updating the firmware it works now.
