[FiiO KA17] Mini desktop-class amp, flagship dongle is officially released!
Feb 10, 2024 at 1:00 AM Post #167 of 747
For headphone, i'd say yes. Same thx amp, now with stronger power and a knob
Feb 10, 2024 at 2:11 AM Post #168 of 747
Are you playing music locally? I don't know what this Samsung music app is. I'm using an s23 ultra and I use musicolet which for me by far is the best local music player. Try it and see if you get same issue.
I've already send it back to my local store. Samsung has it's own music player app that I've been using for a long time and I really like it because it's simple to use. I also tried with pulsar music player and the issue was the same. Maybe I received a bad unit I don't know to be honest... I'll wait for KA15 personally.
Feb 10, 2024 at 2:30 AM Post #169 of 747
There are a lot of options like fast, brick, slow, hybrid but where is "Non OS" option?
This is because ka5 uses cirrus logic dac and ka17 uses ESS dac. These options are offered by the dac manufacturer and passed through the dongle manufacturer to the customer. There is no Nos filter to ka3 either for the same reason.
Feb 10, 2024 at 5:19 AM Post #171 of 747
Hi guys im joining KA17 club.
I have question about the filters.
FiiO can you give us what the Filters do to the sound, i cant find it in your website.
Also is the desktop mode increase Voltage or Current(Amp)?
Anyway i didnt expect dongle nowadays have become so good. Tried RU7 and i can say this KA17 is maybe around the same level as RU7 but cheaper and i like KA17 it sound warmer also i dont experience popping or clicking sound like what Cayin dongle did with my phone.
Feb 10, 2024 at 5:42 AM Post #172 of 747
Anyway i didnt expect dongle nowadays have become so good. Tried RU7 and i can say this KA17 is on the same level as RU7 but cheaper and i like KA17 it sound warmer also i dont experience popping or clicking sound like what Cayin dongle did with my phone.
Here is some references description regarding the difference of ESS' filters: https://www.eversolo.com/Support/su...zeq7k9e[ld]3ulg==/guide_faq/AwkvFko6beQ=.html
As for voltage vs. current: my own measurement suggests both are increased in desktop mode.
Feb 10, 2024 at 6:02 AM Post #173 of 747
Feb 10, 2024 at 6:32 AM Post #175 of 747
Feb 10, 2024 at 6:47 AM Post #176 of 747
Can you explain the different between the 2? Like, why not just increase either or both, what would you achieve if you choose 1 against another?
You means voltage vs. current? Voltage mainly dictate loudness, current mainly dictates tightness / control. For example, increasing voltage makes everything sounds louder, but increasing current improves the notes' sharpness / definitions / stage. For simplification, you can think of voltage gives more quantity while current gives more quality, but to an extent.
What is reverb?
When an audio note is made, it doesn't just disappear when when the actual signal is stopped but a it is actually gradually faded / diminished. Those lingering signal that are the artifact of the original signal is the reverb.
Feb 10, 2024 at 6:54 AM Post #177 of 747
Ahhhh some people call it decay or echo like effect am i right? Also in the link you provided i think it was for other DAC chip 9068 is it the same? Cant find Mini, mini s, apod 1, apod 2 description.
Feb 10, 2024 at 7:58 AM Post #178 of 747
Gotcha. Thank you for the explaination. That must explain the hype or the magic around Questyle stuff huh?
Feb 10, 2024 at 8:24 AM Post #179 of 747
The same filters are more or less the same (*function wise) across different gen of ESS' DAC chip, but they do add more filters option on newer chip, which is what ESS often does as part of their marketing of features. All of these filters have pretty much existed on various older ESS' DAC chip from one point to another, just that they decided to have almost all of them installed in ES9069, plus one 'programmable' filter which you can put the MQA decoding filter in if the manufacturer is willing pay the license.
Feb 10, 2024 at 8:43 AM Post #180 of 747
Questyle is different. What they do is current gain amplification - meaning they used the current signal as the main factors during the amplification process (as opposed to the more common voltage gain amplification). These are the different ways of how a circuit can make a signal larger / smaller, but then the circuit will always need to convert back to voltage signal at the end, then a buffer stage (or something similar) will add current to that voltage signal in order to actually have both components together driving the load (*headphone). The KA17 discussion we have before deals more with the latter, the combined voltage + current signal. Questyle on the other hand deals more on how the signal is increased / decreased before current is added. That's why even though Questyle called it current mode amplification, yet their USB dongles actually don't offer a lot of current driving power to the headphone i.e. M15 is 85mW @ 32 ohm, M12 is just under 50mW @ 32 ohm. In contrast, KA17 is 140mW @ 32 ohm in normal mode and 270mW @ 32 ohm in desktop mode.
