https://majorhifi.com/fiio-k9-pro-review/
""""" Bass and midrange resonance displays an equal amount of transparency, forming a tight resolution that perfectly replicates musicality. I didn’t find the K9 to produce much in the way of added texture, instead it revealed details in a more realistic manner. In terms of gain, the K9 leaves room for improvements. I used the amp mainly at its high gain function, and I still had to turn the knob to almost 3 o’clock in order to find a comfortable loudness. This still leaves you a good amount of headroom, and headphones with lower sensitivities than the Final Audio D8000 and the HiFIMAN Arya should give you even more room for potential volume.
For the imaging and soundstage, I’ve never come across an amp in this price range that preformed such effective spatial properties. I felt like the K9 just had an unlimited amount of breathability, giving airier headphones an unrivaled presence, with the D8000 appearing the most like natural speakers. Greater immersion in the sound field is easily obtained with the K9, as it effortlessly expands upon the added dimension of open-back headphones.
Summary
For its price, the Fiio K9 is incredibly impressive with its build, input/output options, and of course its sound quality. It’s a quite large system, but it preserves a level of solidity that puts it in a class well beyond what you think a device like this should go for. We don’t have a lot of meaty amps like this in this price range, but Fiio has delivered an exceptional unit here that makes the market that much more competitive. """""""""
