so why is my 660s 2 sounding amazing on my k5 pro ess then? maybe i forgot to mention that i have the ess model
FiiO K9 Pro Hi-Fi DeskDop DAC&Bluetooth&Amplifier,XLR/RCA/4.4/Optical/Coaxial interface
- Thread starter FiiO Willson
Thats great then.so why is my 660s 2 sounding amazing on my k5 pro ess then? maybe i forgot to mention that i have the ess model
Unsub to this thread and enjoy the music to prevent consumerism to take over.
Would you be so kind as to indicate the amplifiers you are referring to? I would also appreciate it if you could tell me the volume you listen atI seriously advise you to try using Ananda with some other, obviously quite powerful source. You may be very surprised.
Retrorai
So out of nowhere, my K9 Pro ESS has stopped working completely.
I've tried everything from switching it on and off, holding input for 10 seconds, unplugging and replugging the power cord, and swapping the fuse out.
Does anyone know how to proceed with this? Are there any fixes that I haven't tried yet? For the record, it was working perfectly fine before this.
Unplug it for a few minutes, if that doesn’t work contact Fiio for warranty.So out of nowhere, my K9 Pro ESS has stopped working completely.
stormwrx
Edit: Saw that you replaced the fuse.
Dear friend,So out of nowhere, my K9 Pro ESS has stopped working completely.
Did you check other power cord as well? And the switch in the back panel is on(-) or not? If the issue remains, please contact the seller or support@fiio.com for help.
Best regards
Dimitry188
From among the budget devices, you can look at Topping dx3+ and Fiio K7.Would you be so kind as to indicate the amplifiers you are referring to? I would also appreciate it if you could tell me the volume you listen at
Their parameters are already quite enough to provide high-quality sound with that headphones.
And, of course, Fiio K9 Pro.
With the Fiio K5 Pro, I listened to the Sennheiser HD 650 headphones with a volume level of about 70 percent of the maximum.
The headphones sounded loud enough, but not at all with the sound quality that they can provide.
Thanks for your answer. I would be very surprised if the Dx3+ or the Fiio K7 gives Amanda better quality than the D30 Pro and the A30 Pro, but I will test them If I have the opportunityFrom among the budget devices, you can look at Topping dx3+ and Fiio K7.
Dimitry188
A bundle of two devices D30 Pro and the A30 Pro is also a very good solution.better quality than the D30 Pro and the A30 Pro
I was referring to an alternative to the Fiio K5 Pro.
Retrorai
I've unplugged it overnight and tried to plug it in today as well to no avail. The switch on the panel is indeed switched on, and I don't think there was another power cord included, unless you mean to check the other end, in which I have.Dear friend,
Best regards
I'll contact my seller in the meantime, while looking for new things to try and fix the K9 Pro with.
Thanks for the quick response regardless, can't wait to get this up and running again.
The power cable is just a standard computer cable, it’s rare for those to fail, but it’s worth a shot.I've unplugged it overnight and tried to plug it in today as well to no avail. The switch on the panel is indeed switched on, and I don't think there was another power cord included, unless you mean to check the other end, in which I have.
Amber Rain
- Aug 26, 2016
Does anyone have any problems connecting any of the new Sony Daps (NWWM1AM2/Z2) to the K9Pro via USB? If so, any suggestions? It connects with no problem with my other DAC/Amp.
I'm not getting the connection notification when I try and no sound plays...Surprise, surprise my M11+ connects with no problem.
Dear friend,Does anyone have any problems connecting any of the new Sony Daps (NWWM1AM2/Z2) to the K9Pro via USB? If so, any suggestions? It connects with no problem with my other DAC/Amp.
We are sorry that we do not have the Sony Daps you mentioned for test currently. Does the problem happen in both the usb b and C port in the K9Pro ESS?
Best regards
Amber Rain
- Aug 26, 2016
@FiiODoes anyone have any problems connecting any of the new Sony Daps (NWWM1AM2/Z2) to the K9Pro via USB? If so, any suggestions? It connects with no problem with my other DAC/Amp.
Yes, just checked, it also happened with the USB B port. I am using FiiO cables...
