metalmilitia16
Hi, I want to buy an amp for my hifiman arya se, I'm stuck between fiio k9 pro ess and hifiman ef 400, the only thing that matters to me is sound quality, which one should I choose? Thanks.
That's an out of spec connector, very likely on the cable. Those work in some sockets but have issues in others. You need a new cable.Elira, thank you for your reply.
My seller is also in contact with FiiO, they responded:
"It sounds like the customer isn't fully inserting the Pentaconn connector."
The reply gave me an idea, so I did a test:
When slowly inserting the 4.4mm connector, you can hear different channels playing on the headphones as the connector is being plugged in. First the left channel(low volume), then right channel(low volume), then left channel(high volume), and in the end BEFORE THE PLUG "CLICKS" INTO PLACE you can hear both channels at high volume. At this point I have the full volume available to me at L/M/H gain. But if I push the connector all the way, it will stop playing after a 1-2 second delay and the red LED ring will start pulsating.
So funny enough the device works better if the 4.4mm connector is NOT plugged in all the way.
I know this is not intended use, but I found it interesting.
Cheers
Hi, you can read a couple of reviews, like mine to help you make up your mind.Hi, I want to buy an amp for my hifiman arya se, I'm stuck between fiio k9 pro ess and hifiman ef 400, the only thing that matters to me is sound quality, which one should I choose? Thanks.
I knew you had reviewed both amps and was thinking of posting the links in response, but you beat me to it. Both were informative reviews, and both amps have received almost unanimously good to rave reviews, but I'm seriously thinking of getting the FiiO early next year (when I get the funds, LOL). Although the EF400 would undoubtedly pair well with my Arya Stealth, the almost complete lack of features on the Hifiman, lacking even basic inputs any amp in that price class should have, is a non-starter for me.Hi, you can read a couple of reviews, like mine to help you make up your mind.
https://www.head-fi.org/showcase/hifiman-ef400.25881/review/29050/
https://www.head-fi.org/showcase/fiio-k9-pro-ess.25882/review/28610/
For slightly more warm and organic sound signature it is the EF400.I knew you had reviewed both amps and was thinking of posting the links in response, but you beat me to it. Both were informative reviews, and both amps have received almost unanimously good to rave reviews, but I'm seriously thinking of getting the FiiO early next year (when I get the funds, LOL). Although the EF400 would undoubtedly pair well with my Arya Stealth, the almost complete lack of features on the Hifiman, lacking even basic inputs any amp in that price class should have, is a non-starter for me.
Interesting at lest on my end A/Bing the EF400 and the K9 Pro ESS I would consider the K9 pro slightly bright tilted neutral but the EF400 on the other hand is a U shape with a very noticable boost to the lower treble. While both have quite the smooth attack peak the decay on the K9 pro is quite fast and natural sounding as apposed to the stretched out decay of the EF400.For slightly more warm and organic sound signature it is the EF400.
Strictly neutral but not sharp or fatiguing and still enjoyable the K9 PRO.
Feature - wise the FiiO beats the HiFiMan hands down.
Dear friend,Interesting at lest on my end A/Bing the EF400 and the K9 Pro ESS I would consider the K9 pro slightly bright tilted neutral but the EF400 on the other hand is a U shape with a very noticable boost to the lower treble. While both have quite the smooth attack peak the decay on the K9 pro is quite fast and natural sounding as apposed to the stretched out decay of the EF400.
If you want a fun thicker sound and dont mind the highs boost(which I agree fits alot of the hifiman planars just not their dyanamics sadly) the EF400 is the way to go. Being a thin microdetails sound guy the EF400 is sadly lacking in that department with it not being able to grip the driver like a vice but that makes planars sound less like a layered stack of cards kind of sound so I can understand why hifiman went in that direction.
Oh yeah @FiiO any plans on bringing back the K9 pro AKM with the 4499EX chip preferably with the improvements made to the ESS version?
I read in a review before that they are not but I haven't confirmed that.Does anyone know if the Op-Amps are socketed? I'd like to try rolling Op-Amps to see if it makes any difference.
I don't want to take mine apart just to check.I read in a review before that they are not but I haven't confirmed that.
They probably aren’t and I don’t think it would be wise to replace them. Those THX amplifiers are designed very tightly and all the parts are specific for that design.Does anyone know if the Op-Amps are socketed? I'd like to try rolling Op-Amps to see if it makes any difference.
