BattuUBelin
One question, the analogue output, how come it works according to the volume of the headphone amp and isn't it fixed? Is there any way to make it fixed?
it’s controled by the K5 volume, as in a preamp. No way to make it fixed.One question, the analogue output, how come it works according to the volume of the headphone amp and isn't it fixed? Is there any way to make it fixed?
Dear friend,One question, the analogue output, how come it works according to the volume of the headphone amp and isn't it fixed? Is there any way to make it fixed?
are you sure it's not the rubbish cable that comes with the Amp?I have used this amp for 7 months. Everything is fine. Just few days ago the unit start to turn on and off and disconnect from the PC in usb DAC amp mode. Even though the unit light up while turned on, it seems to fail to to establish connection to the PC via usb. Seems the USB dac circuit has fried. Guys wanting to buy this DAC amp should be aware from this issue.
Dear friend,I have used this amp for 7 months. Everything is fine. Just few days ago the unit start to turn on and off and disconnect from the PC in usb DAC amp mode. Even though the unit light up while turned on, it seems to fail to to establish connection to the PC via usb. Seems the USB dac circuit has fried. Guys wanting to buy this DAC amp should be aware from this issue.
RCA mode works, just the USB mode doesn’t workDear friend,
Sorry to hear about that. Does the other input mode work fine instead? If yes, can you find another usb adapter to check whether the issue remains?
Best regards
Dear friend,RCA mode works, just the USB mode doesn’t work
Having changed USB ports and cables already but no luck so far
The most important improvement would be that it could play 24bit/96khz files in through the optical input from my Chromecast Audio, which it does not despite the specifications.Hello Everyone.
What are the 2 most important features you would need if the K5 Pro were to be upgraded?
I have a big problem with my K5 Pro.
It will not play hi res 24bit/96khz PCM files fed to it through the optical input from my Chromecast Audio. The K5's light glows green but no audio is produced. My dealer replaced the unit but it still has this issue. This is a big disappointment for me because most of my files are 24/96 and I want to use the K5 Pro with the CCA.
Yes I did try the same files, optical cable and CCA into my main system DAC (Maverick Tubedac Plus) and it played no problem.Could you try it with another DAC? Just to be sure the problem lies in the K5 Pro
Hello ,Sorry to touble youYes I did try the same files, optical cable and CCA into my main system DAC (Maverick Tubedac Plus) and it played no problem.
Yes, I could purchase a different streamer such as Raspberry Pi, or buy a different DAC and just use the K5 Pro as a headphone amp. I hoped to avoid spending more on this solution though, given I have two extra ChromeCast audios to use. I guess there is no solution that doesn't involve more $$$Hello ,Sorry to touble you
Under normal circumstances, the K5 Pro's optical input is capable of supporting up to 96k 24bit.
Wouldn't it be better to replace the second end of the fiber optic cable?
