[FiiO K5Pro/K5Pro ESS]Desktop DAC and Amplifier+768K/32Bit and DSD512 decoding+3 gain levels (K5 Pro ESS (Red Version) Is Available Now)
May 19, 2020 at 2:06 PM Post #362 of 638
May 21, 2020 at 5:38 AM Post #363 of 638
First impressions the build is very clean and looks good.
Sound is clean and smooth no distortion very controlled.
My Bitrate doesn't change automatically its stuck on 32bit and 41000khz and glows always blue even when i play flacs. I have to change it by my self then it do i miss somthing ? Player or windows options ? I use it whit the same usb driver i loaded for my Q5s. Do i need another version ?
Hi,
Which software are you using? Have you swiched the output mode in the software to ASIO instead of DS mode?
Best regards
May 21, 2020 at 7:19 AM Post #364 of 638
Hi,
Best regards
It works now thanks i did use tidal and i hab too choose the k5pro as the main device
May 22, 2020 at 11:36 AM Post #365 of 638
What is the best way to connect my q5s as an dac to my k5pro
May 25, 2020 at 9:34 PM Post #366 of 638
Hi,
The K5Pro does not have digital output port. So the Q5s could not work as a DAC for it.
Best regards
Jun 19, 2020 at 11:58 AM Post #367 of 638
I'm very tempted to pull the trigger on the K5Pro.
My problem is that the price is very similar to the Zen DAC and I'm undecided about which one to get.
Also, I will be using it with "difficult" to drive headphones: the AKG K702/K712 (is on my want list) and the AKG K240 MkII (so, I'll be using the unbalanced connection).
I don't know if someone had/has the Zen DAC to compare, but... Is the Fiio K5Pro a good match for these cans (unbalanced) or the iFi Zen DAC would be a better bet?
Jul 13, 2020 at 12:45 AM Post #368 of 638
With the AKG headphones you mentioned, the K5Pro would be more suitable due to the much higher power output compared to the iFi Zen. Into 300 ohms the K5Pro has approx 10 times the power compared to the iFi Zen. I also prefer the newer AKM4493 dac chip in the K5Pro. Hope this helps.
I own the K5Pro and am very impressed. The digital controlled analogue volume control is excellent. No channel balance issues or noise.
I am using it with HQPlayer software to upsample and send it 768k and DSD256 with excellent results.
To Fiio => please enable the AKM4493 DSD bypass mode in a firmware update for dsd256. This would increase sound quality by bypassing the dsd to pcm internal conversion.
Jul 28, 2020 at 9:17 AM Post #369 of 638
It makes my Denon AH-D7200 cans sing happily. (Source: Fiio X5 II connected thru coax S/PDIF). Astounding combo.
Aug 31, 2020 at 1:19 AM Post #372 of 638
Aug 31, 2020 at 2:45 AM Post #374 of 638
My experience changing gain settings is no diference soundwise.
Aug 31, 2020 at 3:53 AM Post #375 of 638
I too don’t hear any sonic difference between the gain levels. All it does is ielevate the noise floor. So only use gain if necessary. That’s the rule of the thumb.
