can someone help:
1) I connected my X3 ii to the usb port on the back of the unit using a micro-micro usb cable. But when i play music, there is no audio from the headphone out of K5. But if i dock the X3 ii on the top of K5, it works. What could be the problem?
2) Is there a way to make X3 ii not charge all the time it is docked. Right now it is charged even when K5 is turned off(using Vol knob)
Dear maheeinfy,
1. From the April, 2016, we already started to make the sample DOCK IN cable special for the back micro USB port at the K5.
Because the micro USB port was 11-pin, the core of that special DOCK IN cable might be about 10mm in diameter after our estimate. Yeah, it was a bit thick.
In order to make the technical index of this cable be same as the K5's Dock connector, we continued to debug its output parameters and linear impedance.
We finally solved the output parameters issue, even though the debugging process was not smooth at firstly. However, when starting to test the sample cable with the K5, we found the X series music players including X3II, X5II, X7 can NOT work as a DAC with connecting this Dock IN cable.
It would be required to make a very big and difficult thechnical change on this cable if we want to solve this above DAC issue.
Therefore, looking at the above factors, including the large diamether of this cable and the difficulty in solving the DAC issue, which cause this DOCK IN cable can not implement the exactly same functions as what the K5's Dock connector does, we sorry to inform you we decide to cancle this project of this DOCK IN cable special for the K5.
2. Sorry, the X3II will be charged when docking in the K5.
power is supplied to the device as follows:
1. While the device is charging
Because the computer USB port has limited current capacity, the battery is given priority for part of the charging current while the rest powers the device directly. But if the current draw by the device is high, the battery participates in powering the device as well. Hence, both the battery and the USB port take part in powering the device while the device is charging.
2. After the battery is full
Because there is no need to charge the battery anymore, the USB port would power the device directly. The battery would neither be charged nor discharged.
In summary of the above, the powering scheme of the X3II ensures that the battery may be fully charged while at the same time guaranteeing proper function of the device. Finally, the battery will be at rest after it is fully charged, thus guaranteeing extended battery life.
Best regards
