peterinvan
Thanks. It’s a Topping rack from Aliexpress. It allows good airflow around the Loki+ which runs quiet hotNice setup. What rack is that? I've got a similar stack just piled up on the desk![]()
Thank you!The Fiio Bluetooth receiver BR13 has an optical and coaxial digital output.
Not balanced. It doesn’t seem to matter to the sound quality when fed into a powerful headphone amp. I use the pre-amp out so that I can use the excellent volume control on the K11R2RIs the line-out mode output of the DAC balanced? I see it only has RCA ports on the back panel.
Thank you! By pre-amp out you just mean from the back panel, right? Or is there some other pre-amp function? My concern was for compatibility pre-amping the Apos Gremlin, which is balanced inputs only. I'm currently running it from a different unbalanced input with RCA to XLR cables, but I know that isn't recommended.Not balanced. It doesn’t seem to matter to the sound quality when fed into a powerful headphone amp. I use the pre-amp out so that I can use the excellent volume control on the K11R2R
The RCA outputs are line out with fixed or adjustable volume (voltage)Thank you! By pre-amp out you just mean from the back panel, right? Or is there some other pre-amp function? My concern was for compatibility pre-amping the Apos Gremlin, which is balanced inputs only. I'm currently running it from a different unbalanced input with RCA to XLR cables, but I know that isn't recommended.
… selectable on the “round robin” menuThe RCA outputs are line out with fixed or adjustable volume (voltage)
My BR13 performs well in my living room rig.The Fiio Bluetooth receiver BR13 has an optical and coaxial digital output.
I don't think so. I have the same DAC/Amp and performs flawlessly with all my headphones, either low and high impedance and sensitivity.Hi all.
I currently use a fiio K5 pro (AKM) and a Sennheiser hd 660s2. Should I upgrade to the k11 r2r?
Yep, it was a shocker for me as well...broke the 'full-size separate desktop rigs needed' for this sound belief.Paired my new FiiO K11 R2R with Sennheiser 6XX and this setup is literally blowing my 70-year-old mind!! Been around the block with headphone gear, but this is setting a very high new bar. Listening now to this:
More comments later when I come down from my high. If I do!
Prepare to be disappointed in the amp section. It’s very weak, imo. I use it only as a DAC. As a DAC, it’s hard to beat!I haven't tried the amp section yet. I've been using it as a DAC only. But I like the sound of it. Maybe I'll try the amp next time I feel like playing around.
