- Jan 30, 2011
How would you be with either making me a cable (I can cover costs), or alternatively a how-to on how you made it? I have heat-shrink, solder etc, and am happy to do a little DIY.
What were you using the E17K with (with the lightning connector). Extremely interested if I could get it to work with an iPhone 5S.
It's fairly straight forward, I noticed that in the cheap knock off chinese CCKs had a larger white plastic bit compared with the genuine apple version. I dismantled the cable and noticed the chip in the plug itself. I was then just a simple case of soldering on the cables of a micro usb lead to complete the cable.
The black rubber bulb is just Sugru the moulding rubber stuff to protect the flimsy usb cables.
I wasn't sure if it was common knowledge about the Chinese CCK cables and whether other people had made their own mini CCKs or not - if it's not I might post up a thread when I make my next one.
Here's a picture of another one I made for the E17K before I sent it back.
10K is far better, k1 just amplifies the sound. I tested both at the same time.
Ok, i understend your point.
Check this http://soundnews.ro/2015/11/27/fiio-q1-english-review/
Is very interesting![]()
I observed small changes to sound reproduction when the device is just turned on and it’s cold comparing to when it’s warm at touch and is runing for some time. When just turned on it sounds less analogic, digital glare is more obvious, bass does not go as deep, and mids do not have substance and are not full sounding. After 30 minutes of warming everything comes back, microdetails are more apparent, sound is becoming like a fluid and listening pleasure returns.
