The apparent process to save a PEQ (at least 3 bands) reliably:
- start with RESET to wipe everything
- then switch to USER2
- long press each frequency and put in frequency, gain and Q (in my case: 300 -3 Q0.71 / 2700 -3 Q2 / 4750 -3 Q2)
- then click on USER2, to get the EQ menu
- click on USER1
- it will now save the custom PEQ on USER1
This makes no sense, but by following these steps, I can get this 3 band PEQ at least to stick.
It sticks now:
- Switching tabs in Fiio Control
- exiting, force closing Fiio Control and re-entering
- disconnecting the buds entirely and reconnecting them
This cannot be the intended workflow to get a PEQ to stick but maybe it helps others get one in and maybe helps
@FiiO get to the bottom of the issue.
The key with it forgetting PEQ, it doesn't seem to forget if you limit yourself to the GEQ and don't long press. It's only if you long press it seems to then be random as to whether it will actually apply what you select or not. It will show it on the graph initially after selection, but not always save it. If it doesn't save it it doesn't seem to actually affect the sound either, so it seems it's only showing on the graph in the app and never going to the buds at all.
For me, and I think many more "audiophile" users, this on-device PEQ is really a key and unique feature that could be a huge selling point. I care about this more than ANC or ambient modes, for the specific use case of these. They are not tuned badly stock, seem to have very good drivers and very good sound with that trademark Fiio punch in the bass and for an IEM really great soundstage, I think these could really be killer if you can just get them to work smoothly.
