helmutcheese
Check the Balance in the App, reset them and update to new FW.
Yes, I did a reset and updated the firmware, but the problem remainedИспользуйте баланс в приложении, сбросьте его и обновите до новой прошивки.
Yes, I have had both, the MTW3 was great sounding but had launch bugs (may be fixed now) and they are too small for me.
The FW5 also can sound great but other times (possibly suites certain genre more than others) be not so good.
It is hard to say since U do not have both here now, but the MTW would have been keepers for me otherwise
Yes! I also noticed this, I hope this is due to the new firmware 1.26, because as soon as I received the headphones, I did not listen to them, but immediately flashed them ...@FiiO I, too, lost the connection at the left earphone, rebooted and heard. In the control application, when you go to the audio tab, the slider jumps immediately from the L2 position to zero, but the feeling that the sound is shifted does not go away.
Same, I thought i was going insane.Yes! I also noticed this, I hope this is due to the new firmware 1.26, because as soon as I received the headphones, I did not listen to them, but immediately flashed them ...
Starting to make me glad I can't afford these quite yet. Going to wait till they are available from a Canadian retailer like Amazon with the issues people are having.
where did you get the 1.26 firmware?Yes! I also noticed this, I hope this is due to the new firmware 1.26, because as soon as I received the headphones, I did not listen to them, but immediately flashed them ...
Fiio controlwhere did you get the 1.26 firmware?
Dear friend,Yes, I did a reset and updated the firmware, but the problem remained
