Can i connect this via bluetooth to car stereo and to my phone and play ldac through system?
FiiO Flagship Portable High-Fidelity Bluetooth Amplifier BTR5 is available now!
You mean you use the BTR5 USB dac feature and stream it via Bluetooth? Not sure that's an option on it. I don't think many car receiver support LDAC either.
It's better to just plug aux from BTR5 into the car stereo and stream LDAC Bluetooth to it IMO.
Dont have aux port only usb. So if my car stereo deck does not have ldac i can not play ldac through the btr5 then?
Most USB on car receiver are only media reader, are there ones that support USB dac input functionality?
Even If it can do that why not just connect your phone straight to it than going through the BTR..?
And no I don't know of USB output function on the BTR5, most ports, whether analog or digital usually goes only one way.
Phone
is connected to usb but music does not sound
as good as it did with the dac to aux port. Was hoping for something to bring the quality up. There are stereo decks with. Ldac, would he a pain to take out deck which I just bought and replace it
Then it's probably designed to only be used to read USB flash drive? I only remember a couple cars that support Apple lightning to USB playthrough but I don't think those ones would support Android or niche brand like Fiio?
Ya then again it won't read certain hi res files
Well yeah, most only support lossy format.
Chris Kaoss
No.Can i connect this via bluetooth to car stereo and to my phone and play ldac through system?
But you can attach the USB charging cable in your car with it.
So the BTR5 will start with your ignition switch simultaneously. ( car mode )
Then pair your phone via bluetooth and connect the 3.5 to your cars aux.
This is how it's meant to be.
There is no aux port. I am replacing stereo with one that has ldac, so no need for the btr5. Returned it problem solvedNo.
This is how it's meant to be.![]()
Chris Kaoss
Saw that on the other thread.There is no aux port. I am replacing stereo with one that has ldac, so no need for the btr5. Returned it problem solved
Dear friend,There is no aux port. I am replacing stereo with one that has ldac, so no need for the btr5. Returned it problem solved
Yes, you may consider a player instead.
Best regards
- Home
- Forums
- Head-Fi Special Forums
- Premier Sponsor Forums and Sponsor Forums
- FiiO
