FiiO Willson
Sponsor: FiiO
Thank you very much for your long reply, what a great project!-----------------------------------------------
There are already many "wishlist" posted earlier, the following are my 2 dozen cents. Even if too late for CP15, hopefully do-able for CP17:
1) Half speed playback
I'm OK if it's never get done. Waaaay too unlikely. How many people still keep their half speed tape recorded from mere dictaphone? Even if they do, the quality may not really require a FIIO player, but...
There were super cassette decks capable of half speed recording in high quality in late 70s/early 80s, intended for long recording of long radio show and music program, before Philips went "how dare you!!" and effectly killed them all.
There's no way playbck can be as good as on the decks it recorded on, but it may be good to have new option other than Unobtonium decks, now where do we get half speed recorded tape for new users?
...or, it doesn't have to be half speed recorded, there's a good purpose for half speed sllroooow pllaaaaybhaaaacchk which I'll get to later.
2) Bass option and tape selector
Already mentioned in many earlier posts, I know. The thing is...there used to be Walkmans with tape selector and bass enhancement, there used to be TCS recorders do half speed, but there's NO model have tape selector and half speed together since lost early super decks.
CP17 may be the ONE chance to bring them together at long last, along with bass enhance option, for...
3) "A middle level player for tape presevation"
It's the true purpose of this whole post and the reason why to have them together. Between hard-to-obtain-and-repair classics like Walkman and flooding cheapos, we finally have W.A.R. and CP13. The same way should go for something proper between TASCAM USB prosumer hi-res-less decks and cheapo all-in-one USB/memory card cassette "digitizer."
I personally don't think there's need for a memory card slot or USB port for CP17. Memory card slot with circuits for proper audio resolution output would obviously take up too much space, there's reason why those cheapo "all-in-one" tiny digitizer doesn't do anything beyond MP3.
No USB, no Windows/Android/Mac compati-worries. Anyone has a bit knowledge and basic quality demand would likely go for a good recorder on receiving end instead of "uselessly convenient" card slot that can't even output hi-res, which seemingly overkill for cassette tape, but it's always better to post-process in higher-than-need resolution then down-convert to relevent res.
And what bass-enhance thing has to do with "tape presevation"? Isn't it defeating purpose of faithful "preservation"?
Answer: half speed capture. That's what aforementioned "slow playback" is really for.
This is what I've been doing for a while: playback normal speed tapes in SONY TCS-600 half speed (one of the few can do that in stereo), into SONY PCM-A10 recorder at 96khz, higher frquency is pulled down a whole octave, away from where most players can't handle well, and then basic cleanup and resume speed in Audacity.
Result: airy and better extended high frequency, a bit attenuated overall volume (about -3db), and ...(you guessed it)... much reduced lower frequency slammed into wall of frequency response curve.
It's overall good performance ratio. For recordings which doesn't have much bass to begin with, it's pretty much done. Maybe some mild EQ on bass, but not too much as it can easily get muddy.
When necessary, I do another "normal speed" take, reduce its speed to match unaltered "half speed" take, painstaking matching them via "Change Speed and Pitch", multiple undo then redo to avoid distortions pile-up, then do low-pass filter to the slowed down "normal speed" track at around 100hz-200hz (or half the figure since speed is yet to be resumed here), where "micro misalignment" would be mostly inaudible. Mix and render, restore speed, a well bass compensated track is done. If there's still segments with audible misalignmemt, just edit and patch with previous takes.
By now you should be able to tell how bass enhance can be handy if it can be activated along side half speed transfer. Type switch and bass enhancement seems pretty much possible by now, but it would be a pity to just leave out half speed alone.
(Or can I get half speed by risking replacing 4.2V battery with 2.1V one?)
My initial idea for "2 speed takes" process was to have CP13, clearly better one for normal speed take (also as an excuse to give my support), and merge with half speed take from TCS-600. Then I figure their speed are never gonna match and dropped the idea, thought that a single TCS-600 would at least guarentee exactly half of its own normal speed. Boy I was so wrong, 51% speed is closer to reality and not even very consistence. Later as I got better at working on speed adjustment and matching, CP13 is back on menu.
Now I'm already on the way of getting a CP13. Though CP15 is already kinda "on the way," but I figure the more income from CP13, the better chance CP15 and CP17 can really come to be.
What's more: Fiio is currently the only one that promised customized new head for future model (I'm yet to find any similar premise from either We Are Rewind or Panda), relying on sales of CP13 so the supplier would agree to do. If it works out, it would mean a new product line of improved new head, which likely means a new choice for ALL tape player makers, future models for professional / prosumer use would no longer be bound by the only head currently available.
It's all about investing a new possibility.
I have some questions for you:
1) Half speed playback-------Is this one really in demand? Since the CP15 is a brushless motor, this would be very easy for us to do, but I've heard very few suggestions like this before, and I assume very few people should be using it
2)Also due to language differences I may not understand you very well.
On the CP13, it is true that the azimuth is not as well adjusted as on digital signal devices, which is a common problem with this movement
On the CP15, we will use heads with no azimuth adjustment, in fact this is Sony's previous experience, I think it does have some use, but it's still worse than digital equipment.
