sidecross
The stock cable while efficient is not to my liking. I use fiio 45cm cable for travel along side btr1k . At home I use fiio 8 strand lace cable at standard length with fiio q5.
You might try 1/16" (1.5mm) cable tie 4" (20.5mm) in length and cut to size needed. I have used this in the past on other cables.The clear cable sheath is quite attractive, though it overall is a bit heavy for portable use. If it weren't for the ear hooks (did I mention those before? ), it could be considered 100% tangle-free.
I like the cable that came with the Japanese-market Sony XBA-30/30ip. It was a durable, ribbed flat cable that was light and resisted tangling. The only reason it failed on me was a questionable crimp design north of the splitter. A chin slider likely would have helped there, too.
Speaking of that, does anyone know of a chin slider design that doesn't slide when you don't want it to?
I've used clips like this before. I've even had to add UV-cure resin to the part that slides onto the cord to keep it on the cord. Clips on the shirt, but doesn't help with ear retention. My chin slider on the FiiO LC-3.5BS helps maintain the IEM seal, but keeps sliding down.I use these as well.
Cable clips:
https://www.amazon.com/BBTO-Pieces-...50677682&sr=1-3&keywords=earphone+cable+clips
I agree that it would be difficult to place the cord lock whose image you have shown to work.I've used clips like this before. I've even had to add UV-cure resin to the part that slides onto the cord to keep it on the cord. Clips on the shirt, but doesn't help with ear retention. My chin slider on the FiiO LC-3.5BS helps maintain the IEM seal, but keeps sliding down.
What I'm think of is something like the spring-loaded cord locks you see for drawstrings. I wonder if I can retrofit one of them? That would mean hacking into it to get it on the cord, and then somehow repairing it. Or hack off those dreaded ear hooks on an existing cable, put the new slider on, and re-terminate with new MMCX (the last part isn't quite so attractive of an option).
http://cord-lock.com/pu64s-mini-drum-cord-lock.aspx
Found my "tip nirvana". I was already using the Symbio N's in medium, but tried @mhoopes trick with the spacer (hopefully just visible in the picture). This has got these as close as perfect for me as I think they're gonna get. Fii0, you have a new fan :-D
I found a similar problem with spinfit and the fh5.Yeah, I need symbios with a spacer to get full enjoyment from my FH5s as well. The only problem is then, (due to the spacer, probably) is that half the time the tip remains in my ear on removal. This happens so often it's not even an issue anymore. I've become adept at getting the thing out pretty easily.
@BobJS , I haven't had that problem myself but maybe it's because I'm using the N Symbio's, and the fact their fit is tighter anyway. Plus, I left enough of a gap behind the ridge on the nozzle to grip the tips (It took a few spacers and sliced-up tips to get it right!) @sidecross I agree, it's definitely a challenge, albeit a fun one for me, to discover which tip works best, especially as straight out of the box, these sounded thoroughly underwhelming, and some people completely green to this hobby(?), with no knowledge on the impact of different tips, might just send 'em straight back decrying their awfulness .I found a similar problem with spinfit and the fh5.
The 155 medium with a diameter of 5.5mm would do the same but switching to spinfit 145 with 4.5mm diameter not only solved this problem, but gave me even better and more fuller fidelity.
Working to get the best out of the fh5 is not for the meek.
I agree, I find the challenge to find an optimum listening experience an art of discovery in of itself; I enjoy problem solving.@BobJS , I haven't had that problem myself but maybe it's because I'm using the N Symbio's, and the fact their fit is tighter anyway. Plus, I left enough of a gap behind the ridge on the nozzle to grip the tips (It took a few spacers and sliced-up tips to get it right!) @sidecross I agree, it's definitely a challenge, albeit a fun one for me, to discover which tip works best, especially as straight out of the box, these sounded thoroughly underwhelming, and some people completely green to this hobby(?), with no knowledge on the impact of different tips, might just send 'em straight back decrying their awfulness .
