[FiiO FH3] 2 BA 1 Dynamic Driver Hybrid Earphones
RikudouGoku
No need to change anything with the denon I think.Thanks, I have never dealt with this so I don't know anything. So sorry in advance for some stupid questions.
So any recommendations for 80% listening on a MacBook and 20% on iPhone for under 100/150$?
When I'm watching movies I'm connected to the Denon AVR-X1600H, do I need something here?
You could go with a bluetooth dac/amp like the Fiio BTR5, Earstudio ES100 or the qudelix 5K.
Otherwise I would go the Ifi Hip-dac or the XDUOO XD-05 basic. You could probably get a separate adapter from usb c to lightning for your iphone and maybe your mac if it doesnt have a usb-c port.
EDIT: I do recommend that you get a good source because that means that you can forget about it for a long time and just focus on the transducer instead.
Especially since this happened: https://www.prosoundnetwork.com/business/akm-factory-fire-shakes-up-pro-audio-industry
Well I think the Macbook will drive them just fine but as I said, you will get the best of them with a decent amp, Its not only a matter of volume. You can get decent amps for 100 or less and they would improve the sound of all your IEMs (Fiio btr5 is my recommendation for his price-quality)Little bit off topic here but do I really need a DAC when my source is to 80% a MacBook? It's driving my IEMs very good (just listening on level 1 to 3 of 16).
Maybe for my iPhone I'm considering to buy one of those small Headphone Amp dongles.
CommanderCute
Thanks, this is great help. Gonna read some reviews now.
Last stupid question: How do I connect a headphone amp to my Macbook (2 USB C ports and headphone jack) when I don‘t use bluetooth?
Because the USB C ports on my Macbook don‘t work with audio when I connect my IEMs with a dongle. Have to use the headphone jack.
RikudouGoku
I am afraid that I cant help you with apple products. It should just be as simple as connecting it to the usb-c port.Thanks, this is great help. Gonna read some reviews now.
H T T
- May 11, 2013
- Messages
- 738
- Reaction score
- 357
Use a USB C to what ever USB connector is your headphone amp input happens to be.Thanks, this is great help. Gonna read some reviews now.
Here is one amp worth investigating: https://www.fiio.com/q3
RikudouGoku
I didn't mention the q3 because it has high output impedance (2 ohms) and low output power (300mw) relative to the others in that price range.Use a USB C to what ever USB connector is your headphone amp input happens to be.
mochill
Ifi hip dac works well with the FH3 as well as many other iems/headphones. It will also fully unfold MQA if you use Tidal - something you are not getting from your Mac or any Bluetooth unit.
Connect it with usb c directly and enjoy. I also use a few Dragonfly products, and for the amount of crap some give them, they sound good and are extremely convenient and portable. No balanced outputs or physical volume adjustment (which is very nice) like the hip dac, but full 24 bit processing.
I notice a big difference when using an outboard dac/amp vs my Mac, and if you plan on expanding your collection to some harder to drive headphones, it will be a must. Good luck!
H T T
- May 11, 2013
- Messages
- 738
- Reaction score
- 357
I'm an Apple user and have found that FiiO is quite Apple-friendly. I was mainly going by my experience with FiiO and Apple products, not with specifications. You bring up good points.I didn't mention the q3 because it has high output impedance (2 ohms) and low output power (300mw) relative to the others in that price range.
Forgot to mention another DAC AMP which is often overlooked because of the brand and its advertised as gaming product, the Sound Blaster Xg6. For me its better sounding and more versatile than loads of 200+ dac amps, plus its lightweight. It has insane amount of power, can easily drive all the cans you throw at them, and It's capable of 32 bit 384 khz. You can get it under 100 on black friday and for that price it's such a steal.
H T T
- May 11, 2013
- Messages
- 738
- Reaction score
- 357
It isn't really Apple-friendly. Nicely spec'd, though.Forgot to mention another DAC AMP which is often overlooked because of the brand and its advertised as gaming product, the Sound Blaster Xg6. For me its better sounding and more versatile than loads of 200+ dac amps, plus its lightweight. It has insane amount of power, can easily drive all the cans you throw at them, and It's capable of 32 bit 384 khz. You can get it under 100 on black friday and for that price it's such a steal.
I think FiiO or Lotoo PAW S1 would be top choices, given the requested Apple platform.
Thats bad, I dont know whats wrong with companies and Mac support, they should offer the same optimization for Windows and Mac. Never heard of that Lotoo Paw S1 but specs looks really good and its portable so I might be a great option for Mac users.It isn't really Apple-friendly. Nicely spec'd, though.
H T T
- May 11, 2013
- Messages
- 738
- Reaction score
- 357
I agree, especially when Mac/iOS are notably the platforms of choice for most music creation. I also understand that the population of music creators is much, much less than music consumers. The Lotoo is highly rated and absolutely worth investigating. I am quite pleased with FiiO products and their interaction with my Apple products. FiiO's supprt is excellent here at Head-fi.Thats bad, I dont know whats wrong with companies and Mac support, they should offer the same optimization for Windows and Mac. Never heard of that Lotoo Paw S1 but specs looks really good and its portable so I might be a great option for Mac users.
For the cynics: I am not a paid FiiO shill. I just recognize quality for my needs and means.
FiiO's BTR series of Bluetooth also supports connecting to a computer or phone via USB DAC
