biostik
Good tip . However I did use the exact same tips as I did before when I listened to them when all was just fine, Final E tips. But have tried several others, that is not the problem I'm afraid.Try out some different tips?
That's indeed what I'm afraid off. But is there somehow a tool to measure this?Begs to question what changed if they once sounded good. Maybe the pair you have is defective?
Are you using the same source? Did you purchase from here? FD5 responds well to EQ.That's indeed what I'm afraid off. But is there somehow a tool to measure this?
Now it sounds just like a cheap IEM. Also tried to EQ the bass a bit which before with the demo set was very easy but now it seems to have almost no effect.
Indeed all settings equal as before. How do you mean purchase from here? And indeed my experience was also they respond good to EQ but now not anymore . I will do some further research. I have the feeling something wrong with the driver? Maybe previously guy had them in the washerAre you using the same source? Did you purchase from here? FD5 responds well to EQ.
How knows. I try to contact Fiio Netherlands here as they are purchased there and I have the invoice
Check the removable nozzles (aka sound tubes), maybe the prior owner added some sort of sound dampening material, to either the inside or the outside of the screens.Ok did receive my FD5s. I did listen to these before and was impressed with the soundstage and authoritive bass. But What, where have they gone ....Totally not impressed, poor bass, poor soundstage. The guy before me had these 6 months, one would say these have burned in. If someone has a tip for me I would be glad to hear
Good tip. Fiio here in the Netherlands suggested also to check the nozzles. Don't think this is it because I did already remove the nozzles to check everything. But will check it today againCheck the removable nozzles (aka sound tubes), maybe the prior owner added some sort of sound dampening material, to either the inside or the outside of the screens.
With certain tips, the deeper you tight the earphones in you ears, the worse the sound becomes. You can do it without problems if you use the foam tips but with the silicone tips, I recommend you don't tighten too much and find the right compromise.Update: I did clean the nozzles and did some further testing. The sound has improved definitely, so good news. I think there are 3 factors which caused my bad listening experience.
1. Maybe the nozzles were indeed not clean (although I don't think this was the case)
2. My expectations were maybe higher to begin with
3. This one is i think the cause: the nozzles were getting loose in my ear because of the fiddling/ fitting, i always twist the IEMs in my ears. So I did make them real tight so they don't can't come loose.
And I think they are maybe not properly burned in yet. The previously owner says he did use them for 100 hours so don't know if that is enough ....
So happily to report that everything is alright with the FD5. Thanks for thinking with me all
