What a ugly frequency response...
I was interested but seeing that, clearly i lost all interest
That particular reviewer has a challenged history with dynamic drivers, as he's not open to the possibility that the driver may need to be broken in.
Case in point, he also found the Fiio FH7 and the Dunu Luna to be lacking, in presence.
If you want to take less of a financial gamble, there should be reviews on the Jade Audio EA1 by the middle of next week; on paper, it looks to be virtually the same IEM, at half the FD1 price.
(link to listing)
Based on the copy being exactly the same (on Amazon),
except for the description of the respective cable:
EA1
[Flagship-grade beryllium-plated diaphragm driver]With JadeAudio's typical flagship-grade headphone technology, the EA1 headphone dynamic driver is made of high-end beryllium, known for being light, thin yet extremely rigid. It brings you a sense of movement and power, shaping majestic sound performances. That means 4 times more rigid than steel, three fourth lighter than titanium,and sound velocity up to 12KM/s.Extraordinary configuration just perfectly matches with you.
[Two-way magnetic circuit design,powerful driven capacity]The EA1 earphone dynamic driver is designed with an N50 two-way magnetic circuit having a 55% magnetic flux promotion and nearly 1 Tesla of magnetic field intensity compared with the traditional single magnetic circuit. The double magnetic flux activates forceful driven capacities that enable energetic, robust bass performances and even full and delightful transient responses.
[Patented balanced pressure relief technology,for long-time wearing]The beryllium diaphragm coupled with the two-way magnetic circuit design allows improved bass acoustic pressure and deeper bass explosion. Plus FiiO patented balanced pressure relief technology, the pressure is able to stay in a balanced state after precise counting and adjusting.You can comfortably enjoy hi-res music for a long time with no burdens.
[Gold-plated retaining ring, stable vocalization unit]The EA1 earbuds is meticulously designed with a gold-plated aluminium alloy retaining ring and sound tube for each unit, beautifying the EA1 and simultaneously providing way stable cavity for the audible unit, achieving incredible sound quality. The loose and atmospheric bass, clearly transparent mids and high-resolution treble, are specially tuned with relatively balanced distributions.
[Higher-standard upgraded accessory,
4-stranded high-purity monocrystalline copper cable]Included with the EA1 is the cable made of braided Litz wires, 24 cores per strand, 4 strands in a total of 96 cores. Each Litz wire is insulated from each other, ensuring better audio transmission performance under the naturally-occurring yet .
FD1
[Flagship-grade beryllium-plated diaphragm driver]With FiiO's typical flagship-grade headphone technology, the FD1 headphone dynamic driver is made of high-end beryllium, known for being light, thin yet extremely rigid. It brings you a sense of movement and power, shaping majestic sound performances. That means 4 times more rigid than steel, three fourth lighter than titanium,and sound velocity up to 12KM/s.Extraordinary configuration just perfectly matches with you.
[Two-way magnetic circuit design,powerful driven capacity]The FD1 earphone dynamic driver is designed with an N50 two-way magnetic circuit having a 55% magnetic flux promotion and nearly 1 Tesla of magnetic field intensity compared with the traditional single magnetic circuit. The double magnetic flux activates forceful driven capacities that enable energetic, robust bass performances and even full and delightful transient responses.
[Gold-plated retaining ring, stable vocalization unit]The FD1 earbuds is meticulously designed with a gold-plated aluminium alloy retaining ring and sound tube for each unit, beautifying the FD1 and simultaneously providing way stable cavity for the audible unit, achieving incredible sound quality. The loose and atmospheric bass, clearly transparent mids and high-resolution treble, are specially tuned with relatively balanced distributions.
4-stranded high-purity monocrystalline copper cable]Included with the FD1 HiFi headphone is the cable made of braided Litz wires, 30 cores per strand, 4 strands in a total of 120 cores. Ensuring better audio transmission performance under the naturally-occurring yet
