FiiO concept design-From @JamesFiiO
Dongle DAC with a magnetic battery pack
FiiO Desktop HIFI Active Speaker Concept Design (1)
FiiO Desktop HIFI Active Speaker Concept Design (2) Geometric section speaker
FiiO Desktop HIFI Active Speaker Concept Design (3) A Nordic Style
FiiO Desktop HIFI Active Speaker Concept Design (4) Mecha Warrior
FiiO Desktop HiFi Active Speaker Concept Design (5)
FiiO Desktop HiFi Active Speaker Concept Design (6)
FiiO Desktop HIFI Active Speaker Concept Design Summary
Appreciation of earbuds concept design (1)
Appreciation of earbuds concept design (2) Metal flat-head earbuds
Appreciation of earbuds concept design (3) Alien-like earbuds
Appreciation of earbuds concept design (5) Dance with your nunchakus!
Appreciation of earbuds concept design (6) Handsome helmets
FiiO's Dongle DAC KA3 has been well received since its launch. However, there are indeed some problems with this kind of dongle DAC, which are mainly reflected in:
1. The Dongle DAC need to be powered by your phone. To achieve good sound quality, the power consumption wouldn't be small, which will lead to obvious decline of battery life after listening to songs.
2. Some phones have restrictions on power supply to external devices or music apps might be killed in the background when supplying power to external devices. This also leads to compatibility issues and the user experience is not good enough.
Therefore, we designed an additional battery pack, which uses a magnetic interface to dock with the Dongle DAC. In this way, you can choose to use this external battery to power the dongle to improve performance, reduce power consumption and improve reliability and stability.
If you think that the battery pack will bring extra weight and affect portability, you can easily remove the battery pack and still use it as a very small and portable dongle.
How do you like this idea? Please share your opinions with us in the comments below.
Appreciation of earbuds concept design (4) Just like a spaceship from outer space!
FiiO HiFi desktop active speaker User survey (1) Is the Bluetooth function necessary? Or should we place costs on sound quality as much as possible?Appreciation of earbuds concept design (5) Dance with your nunchakus!
